Author Topic: ‘73 750 shifter question  (Read 795 times)
Offline Mark K
« on: October 19, 2022, 06:49:45 AM »
Reassembled the shifter bits last evening. Should I be able to shift thru all the gears without the engine turning? The engine is out of the bike on an engine stand, cylinder not on (still), but pistons are mounted and I do not want to turn the engine without the cylinder installed.
I’m able to shift into 1st, 2nd & 3rd, but it won’t go any further.
I’m asking as I was watching the Hack-a-week video on the shifter reassembly and he was able to shift thru all the gears without turning the engine over.  My concern is that since I just reassembled the transmission internals and joined the case halves, that I may have something out of place?
Thanks
« Last Edit: October 19, 2022, 07:46:02 AM by Mark K »
'13 Yamaha FJR1300, '73 Honda CB750K3 (current project), '19 Kawasaki KLX 140G, '72 Honda CL70K3, '70 Honda SL350 (next project)
Former bikes
'74 Yamaha 60, '72 Maico 250, '74 Kawasaki 250 S1, '82 Kawasaki KZ550, '84 Honda VF700F Interceptor, '99 HD FLSTS Heritage Springer, '97 HD FLHTCUI Ultra Classic '05 HD FLHT Electraglide, '9? Buell Lightning, '03 FLHTCUI Ultra Classic,'14 Honda CRF250L
Re: ‘73 750 shifter question
« Reply #1 on: October 19, 2022, 07:49:29 AM »
You normaly need to turn at least the output shaft
Offline Mark K
« Reply #2 on: October 19, 2022, 07:54:32 AM »
Thanks bryanj, this is the first total teardown and rebuild that I've attempted and am trying very hard to avoid mistakes!
Former bikes
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #3 on: October 19, 2022, 07:58:22 AM »
Yes, rock either the crank or output shaft
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #4 on: October 19, 2022, 09:34:10 AM »
Think of it in practice, the only time you will shift with only 1 shaft turning is at standstill going either into 1st or neutral, once moving shifting occurs with both shafts turning
