SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Front Turn signal issues
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Front Turn signal issues (Read 550 times)
JDrider
Enthusiast
Slowly becoming an uncertified cb550 mechanic
on:
November 06, 2022, 06:42:20 AM »
1975 cb550k1
Correct bulbs
I assume I have a ground issue.
Front Turn signals won’t blink since I bought 3 weeks ago.
However, I noticed that if I pull in the clutch, the right turn signal will blink when turned on.
The left won’t.
What is going on?
Thanks.
Logged
JD
1975 CB550K1
JDrider
Enthusiast
Re: Front Turn signal issues
Reply #1 on:
November 06, 2022, 09:45:34 AM »
After working the clutch a few times the right turn signal seems to be working.
So I guess there is an issue with the clutch switch?
The left turn signal is still not working.
How can I check the grounds and where?
Logged
JD
1975 CB550K1
JDrider
Enthusiast
Reply #2 on:
November 06, 2022, 02:50:33 PM »
Turning it on a little later, the right turn signal only comes on a blinks when the clutch is pulled in.
The headlight will come on sometimes. Once it’s on it stays on till it’s turned off.
Logged
JD
1975 CB550K1
newday777
Really Old Timer ...
Avatar is my 76 K6 in Colorado w/Cody on back 1980
Reply #3 on:
November 06, 2022, 03:57:50 PM »
Do you have the bike running while doing this?
Are you still running the old turn flasher relay?
Logged
Stu
My current rides
Prior bikes....
JDrider
Enthusiast
Reply #4 on:
November 06, 2022, 04:09:37 PM »
I was not running the bike.
I’m not sure about the relay.
The rear signals work fine.
Logged
JD
1975 CB550K1
RAFster122s
I feel like a really really
SOHC4 member # 2605
Reply #5 on:
November 06, 2022, 05:06:35 PM »
Turn signals usually only work when bikes are running on these old Hondas.
Probably a good idea to charge your battery before doing more testing with bike running.
Logged
MauiK3
A K3 is saved
Old Timer
Old guy
Reply #6 on:
November 06, 2022, 06:05:45 PM »
My stuff works with just the he ignition on and a charger battery.
Logged
1973 CB 750 K3
10/72 build Z1 Kawasaki
Don R
My Sandcast is a
Saver of unloved motorcycles.
Reply #7 on:
November 06, 2022, 06:18:32 PM »
Corrosion in socket, bulb bad looks good, wires wrong in headlight bucket, low voltage, corrosion in bullet connectors, bad ground, I'd begin in the socket, then in headlight bucket. A test lamp may tell you a lot.
Logged
newday777
Reply #8 on:
November 07, 2022, 01:29:53 AM »
I keep my batteries on a tender while in the shop and especially when working on electrical problems so it's fully up on charge. A new flasher relay is cheap and sometimes it can help on flashing properly.
Did you use clean the barrel and pin connectors and use pliers to tighten them up? They do open up over time and need a little tightening. Did you wiggle the connectors in the headlight and the wires to the turn signals to see if the flash got working? You can use a multi meter on tone to test the bullet connector to the socket pin to test the wire continuity, wiggle the wire to see if it changes/looses tone. Is the solder end of the wire in the socket good? The solder can dimple over time and loose connection to the bulb(wiggle the bulb in the socket) I've also seen good looking bulbs that the glass was loose to the metal and had lost the gas charge in the bulb.
Use a test lead(alligator clips) ground from the frame to the bolt on the turn signal stem to test the ground.
Logged
Stu
My current rides
Prior bikes....
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
