Author Topic: 350F Piston Ring Compressors  (Read 1138 times)
Offline sfhurst
« on: November 21, 2022, 06:21:59 PM »
Rebuilding the top end of three 350Fs.  All of my manuals show the use of four ring compressors.  Is there another way?  If not, can anyone suggest a source for compressors for the small
350F pistons?
Offline Mark K
Re: 350F Piston Ring Compressors
« Reply #1 on: November 21, 2022, 08:06:18 PM »
sfhurst,
Take a look at this post - http://forums.sohc4.net/index.php/topic,191043.msg2223439.html#msg2223439
Hondaman said he uses his fingers for the 350F pistons.
Also that link has some discussion about some type of ring compressors used on chainsaw engines (smaller pistons). There's an Amazon link to where the one guy got his compressors. Hope this helps you.
« Last Edit: November 21, 2022, 08:09:46 PM by Mark K »
'13 Yamaha FJR1300, '73 Honda CB750K3 (current project), '19 Kawasaki KLX 140G, '72 Honda CL70K3, '70 Honda SL350 (next project)
Former bikes
'74 Yamaha 60, '72 Maico 250, '74 Kawasaki 250 S1, '82 Kawasaki KZ550, '84 Honda VF700F Interceptor, '99 HD FLSTS Heritage Springer, '97 HD FLHTCUI Ultra Classic '05 HD FLHT Electraglide, '9? Buell Lightning, '03 FLHTCUI Ultra Classic,'14 Honda CRF250L
« Reply #2 on: November 21, 2022, 09:50:26 PM »
Unless its been way overbored the taper on the cylinders at the bottom is enough as long as you take care
Offline Kenzo1979
« Reply #3 on: November 22, 2022, 06:57:54 AM »
I remember using my fingers on my 500 when I rebuilt. But I think another tip I found was using hose clamps. Although it was so long ago I can’t exactly remember.  it may have been a combination of both. I may have used my fingers for the first two and then when there was less space for the second two I used the hose clamps.  I definitely had an extra pair of hands helping me as well.
--Kenzo
** 71 CB500, 74 CB550, 76 CB400F, 77 CJ360t **
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: November 22, 2022, 08:47:17 AM »
+1 on “extra hands”. The easiest way I’ve found on our SOHC bikes is to have three pairs of hands!
One handles the barrels, and one pair on each piston being being inserted. Sounds complicated but actually works the best...... two guys feeding in the rings and one holding the barrel goes smoothly.
Offline sfhurst
« Reply #5 on: November 22, 2022, 09:33:19 AM »
Thanks for all the replies.  Off to the shop to try them.
Offline ozm29c
« Reply #6 on: November 22, 2022, 01:14:05 PM »
I think that this guy has got it nailed using Zip Ties. Not a CB350F in the Youtube link but you can see that the Zip ties seem to work well.
Offline MetricMotowerks
« Reply #7 on: November 22, 2022, 04:01:18 PM »
I like to use my fingers, but I've also used band clamps.
