Author Topic: K1 750 interchangeable K0 750 tubes  (Read 2098 times)
Offline Tews19
  • I am no
« on: November 27, 2022, 08:39:07 AM »
I know the fork seals are different for the early K0s. Does anyone know for sure if the K1 fork tubes work with the K0 fork lowers?
1970 Honda CB750 survivor.
Re: K1 750 interchangeable K0 750 tubes
« Reply #1 on: November 27, 2022, 03:12:47 PM »
K0 and K1 both use 35mm tubes, 23” long. I believe the lowers are interchangeable too. You’ll have to use the 1969-71 brake bracket and front fender to match.
If you read the Sandcast Only forums you will see there are minor differences in the top area (were the rubber gaiters attach). If you stumble on an early set you can easily trade for whatever you want + $.
« Last Edit: November 27, 2022, 04:12:27 PM by BenelliSEI »
« Reply #2 on: November 27, 2022, 03:43:38 PM »
 I believe they do interchange. I bought a set of replacement tubes for a sandcast fork set and didn't need to specify except 69-71.
 I think the supply of replacement tubes is running low, prices are reflecting this as stocks run out. I just overpaid for a set of -2" K2-6 style fork tubes also known as cb550 stock length.
« Last Edit: November 27, 2022, 04:26:04 PM by Don R »
Offline Tews19
  • I am no
« Reply #3 on: November 28, 2022, 02:03:08 PM »
What do you mean? I am lost and I am pretty familiar with the bikes
« Reply #4 on: November 28, 2022, 02:57:44 PM »
 The sandcast and early forks have a sharp angle below the fork gaiter/seal area where the later forks have a smooth taper below the gaiter/seal area. The only difference is appearance.  They both use the C shaped brake bracket and take the early fender mount type.
« Reply #5 on: November 29, 2022, 06:16:45 AM »
Don is absolutely correct..... It’s a very subtle difference. I had to have the two types side by side to actually see the difference. I’m currently restoring a very early Sandcast and slowly learning about these things.
Offline Tews19
  • I am no
« Reply #6 on: November 29, 2022, 10:18:12 AM »
You're talking about the lip before the gator attaches? I know that. I assumed you meant something else
Offline Tews19
  • I am no
« Reply #7 on: November 29, 2022, 10:22:18 AM »
Mind sharing a picture of what you're talking about?
« Reply #8 on: November 29, 2022, 10:44:00 AM »
All righty then..
   The one with the plastic on the tubes is a K3 newer style, in the middle is a K1 with the taper under the seal area and on the right is a K0 with the sharper top angle.
   Perhaps someone knows what serial number or model the change to the smooth taper happened? I have a very late K0 with a 71 title and believe it came with the tapered fork top but am not positive.
« Last Edit: November 29, 2022, 10:58:35 AM by Don R »
« Reply #9 on: November 29, 2022, 02:30:31 PM »
Don..... Nice. It becomes obvious! Here’s my very early S/C, with the sharper edge. Thanks!
Offline Tews19
  • I am no
« Reply #10 on: November 30, 2022, 09:05:02 AM »
All righty then..
Yeah, I know of the lip. I assumed you were talking of something else.
Online newday777
« Reply #11 on: November 30, 2022, 01:07:21 PM »
All righty then..
Great information and picture to see the difference 👍
« Reply #12 on: November 30, 2022, 09:40:14 PM »
 I guess a picture is worth a few hundred words.
Online newday777
« Reply #13 on: December 01, 2022, 04:41:44 AM »
A picture still needs words to draw the proper attention....
