Author Topic: Well it Damn Sure Isn't a Honda  (Read 4569 times)
Re: Well it Damn Sure Isn't a Honda
« Reply #50 on: February 08, 2023, 08:46:54 AM »
SprayMax makes good stuff. Repaint supply.com.has good prices on SprayMax clears and few other products they carry of SprayMax (epoxy primers and primers and similar...
Offline britman
« Reply #51 on: February 08, 2023, 02:02:44 PM »
Anything connected with SprayMax is an excellent product.  I always use their 2K clear, once cured it even stands up to gasoline so perfect for the tanks.  Just a word of advice, if you use SprayMax in any form, pull out the respirator, it is pretty nasty stuff as far your lungs are concerned....
« Reply #52 on: February 08, 2023, 02:14:28 PM »
Yes, 2k paints require a good organic vapor respirator and all skin covered, the 2k paints are highly toxic and can be lethal. The toxic substances can mess you up for life if they don't kill you. So, don't screw around with them...take precautions.
Excellent product at an acceptable price for the protection you get, being impervious to fuel, brake cleaner, brake fluid, acetone, etc.
Offline britman
« Reply #53 on: February 11, 2023, 01:04:42 PM »
It is starting to reassemble a motorcycle a little more with each nut and bolt.  I have gone back and rubber mounted a lot of parts, it does vibrate, it may help a little once it is off blocks and back on rubber.  I installed the chrome exhaust tips I found in my stash of extra parts. I did cut down a couple of baffles and fitted them into the extensions for a little back pressure, they really didn't much for sound reduction however.  I still fiddling with the rear brake rod adjustment and mounting a stop light switch.  I also have some chain issues with it just barely touching the battery box, a little wheel of death action will remedy that. Once the tank cures for a few more days, a trip around the block will be in order.  I think I have the carbs somewhat close, starts great, throttles up, and will idle all day. I need to clean the front end up and paint the wheel, that is going to wait for a warm day to use Mother Natures booth with the epoxy paint, the overspray is awful with that stuff....
« Reply #54 on: February 12, 2023, 05:37:26 AM »
Your paint work really looks good! Coming together nicely.
Offline jgger
« Reply #55 on: February 12, 2023, 10:02:03 AM »
I don't know if it was discussed earlier, but that is an interesting lace pattern on the rear wheel. Did you have to custom drill the rim?
Offline Kelly E
  • Geriatric Hooligan
« Reply #56 on: February 12, 2023, 10:17:28 AM »
A brake light switch down under the return spring so the switch spring can share the hole with the return spring might work and be out of the way.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline WideAWAKE
« Reply #57 on: February 12, 2023, 10:48:39 AM »
That’s a stock 48 spoke rim.
Pretty sure it only came on the 82/83
Offline britman
« Reply #58 on: February 16, 2023, 01:05:12 PM »
Well first trip around the block today and I must admit I am impressed how well the Yamaha runs.  Pulls strong, shifts like butter, and no hesitation what so ever.  I still need to do some minor adjustments to the throttle cable and seat configuration but I am afraid I may end up keeping this one.  A few more miles will make the final call......
« Reply #59 on: February 16, 2023, 01:44:14 PM »
Great looking ride. Like my chopper, bet someone talks you out of it!
« Reply #60 on: February 16, 2023, 03:57:36 PM »
I think it looks far better in green than red.
