Author Topic: just showin off...  (Read 4639 times)
Offline cben750f0
just showin off...
« on: June 14, 2005, 01:27:55 AM »
just wanted to show you what i have been up to the last few nights.. and am quite proud of ;D..peace
« Last Edit: July 19, 2007, 04:22:45 AM by Glenn Stauffer »
Offline oldbiker
  • I HATE RAIN
Re: just showin off...
« Reply #1 on: June 14, 2005, 03:09:59 AM »
Hi cben, do you fancy coming round to polish my dining room table?
Offline Brookesy
« Reply #2 on: June 14, 2005, 03:25:32 AM »
cben,
G'day from sunny Queensland...
(Although it's actually raining right now)
Nice work - i hope i can find a project soon too
CB750 K1 - undergoing restoration (on hold)
CB750 K2 - Wanted - More time to work on her
CB1300S - the most awesome bike i've owned yet
Z1000 1977 - Wanted - a head in rebuildable condition
Offline Raul CB750K1
« Reply #3 on: June 14, 2005, 03:29:15 AM »
Don't you have nothing better to do at nighttime?   ::)
Raul
Offline cben750f0
« Reply #4 on: June 14, 2005, 04:05:59 AM »
mates, i have alot of time on my hands, still on rehab from an accident 12months ago, so i only work 3 days, 4 hours, so that leaves alot of time to try nd keep myself occupies.... if it can be polished, it will be.. ;D.. also did the rear brake master cyl mount on the weekend aswell, so i am starting to run out of stuff to polish... though i am looking at the forks... :P..peace
Offline Uncle Ernie
« Reply #5 on: June 14, 2005, 04:34:45 AM »
Having been laid up for a long period myself, I'm completely sympathetic. I try to help out when ever possible because I know how boredom and depression and actually slow the healing process. I'd like to help if I may; send me your address and I'll be glad to send you some parts to polish. No thanks needed- it's just the way I was raised.
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #6 on: June 14, 2005, 06:10:58 AM »
That's pretty shiny - I can make out what appears to perhaps be the box from your Sony digital camera in the reflection  ;)
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
« Reply #7 on: June 14, 2005, 07:01:57 AM »
(Sobbing)   Uncle Ernie....   You have made me believe again in the goodness of mankind...  LOL
Offline cben750f0
« Reply #8 on: June 14, 2005, 05:49:07 PM »
uncle ernie... thanx for the kind thoughts... you are a beautifull human being... ;D
and i cant work out what the eflection is... ???
peace
Offline cben750f0
« Reply #9 on: July 05, 2005, 05:30:52 PM »
well thought i would show ya's the new head and rocker cover on the F1.... yep still showin off... ::) :P..peace
« Last Edit: July 19, 2007, 04:24:09 AM by Glenn Stauffer »
Offline 6pkrunner
« Reply #10 on: July 05, 2005, 05:36:00 PM »
Very nice indeed. What grit wetsandpaper did you stop at before polishing. I'm doing the legs, cases, and cover for a K2 and am at 600 grit wet. How far did you go?
Offline cben750f0
« Reply #11 on: July 05, 2005, 05:40:36 PM »
the stator cover is as the factory left it... though it is a after market one, and doesnt match up to the transmission cover very well, still polishing the stock cover, the trans/chain, and rocker cover... i went to 1200 wet AND DRY... THOUGH IT TEND TO BE PEDANTIC.... ::).. have also polished the rear brake mount, and the clutch casing, also the finned clutch cover... will do the forks when i get another set or another bike... this bike is my only transport... so cant be off the road long... peace
« Reply #12 on: July 05, 2005, 05:42:27 PM »
Probably worn out 1200! ;D
« Reply #13 on: July 06, 2005, 04:35:36 AM »
Thassa nice job Ben, what model head did you fit? Cheers, Terry. ;D
Offline cben750f0
« Reply #14 on: July 06, 2005, 05:41:40 AM »
dunno. it had exhaust valve seals, and the same number of fin spacers as my old head... got it off PUD in the 750/4 owners club.... seemed to work alright, but its running lean again with this head... was just starting to get colour in the plugs with the rooted head, but now i am back to white(clean) plugs.... so am still fiddling with jetting.... BTW terry, saw a hockheed oil cooler go on ebay for over 200 dollars!!! is that right... you need to seel your adapters on ebay mate... would make a fortune!!!! peace
« Reply #15 on: July 06, 2005, 05:30:39 PM »
G'Day Ben, thanks for that, yeah I saw that auction and fell about laughing, I've got half a dozen of those potmetal adapters hanging in my garage, I must buy some more coolers and sell them as a "set", in fact I can do one now as I've bought a CB900 cooler for my racer project and I'll adapt it to suit my "Terry-Built" adapter, so I can sell a nice Derale cooler "set" I've been saving, on EvilBay.
So what was wrong with your rooted head? Was it fin damage, or valve problems? Clyde reckons that F1 heads are probably the best you can put on either a K or even an F2, and I'm inclined to agree with him. Cheers, Terry. ;D
Offline cben750f0
« Reply #16 on: July 06, 2005, 05:58:42 PM »
the PO had tried to screw a spark plug in on the piss... and broke the top out of the thread and stuffed it, so he helicoiled it, but didnt repait the sealing face for the spark plug washer to seal on, over time the exhaust gases ate all the alloy away from the thread repair and wouldnt seal.... and because i was doing alot of plug chops trying to get the fuel mixture right, the helicaoil actually screwed itself into the combustion chamber.... the piston had little marks all over the top near the spark plug hole... there were about 4 threads stretched into the head area... just luck i decided to do the head swap when i did and not after it had broken off...you get that i s'pose on a an old bike...
