Author Topic: Tire Tube Readings  (Read 1860 times)
Re: Tire Tube Readings
« Reply #25 on: January 13, 2023, 11:59:34 PM »
I use Michelin Airstop tubes. An internet shop here had sale last year so I have some for front and rear. Standard as well as thicker. Assembly mistakes must have extra, redo and forget ;)
The valve tool was often shipped with tubes in the 80's, other side of the metal cap. Today only plastic caps with no tool.
It must be possible to reuse if used 5000-6000km and less than a year?
If it survive the tire removal ;)
Offline newday777
« Reply #26 on: January 14, 2023, 04:08:29 AM »
It looks like American Moto Tire has the Michelin Airstop tubes
https://www.americanmototire.com/motorcycle-tubes/michelin-tube-70-100-19-heavy-duty/
Stu
My current rides
Prior bikes....
Offline Ellz10
  • ZZ
  • Knowledge is Power
« Reply #27 on: January 14, 2023, 08:23:48 AM »
Over on the Royal Enfield forums the Michelin Airstop tubes are thought to be the best. You can get them at Hitchcock's and they ship to the States.
https://accessories.hitchcocksmotorcycles.com/s.nl?ext=F&sc=1&category=&search=tube%20michelin
Unfortunately they don't have a rear tire for 150/70. I ended up getting Metzeler HD in the rear, same brand in the front, but standard - and then Drag Specalties 2" and 3.1" rim strips.
Thankful for everyone on this forum. Grateful to continue to learn so much.
'77 K7 - http://forums.sohc4.net/index.php/topic,193043.msg2251436/topicseen.html#new
« Reply #28 on: January 16, 2023, 07:14:19 AM »
You mean the valve caps that had the built in tool?  My buddy had a "collection" of them so I put two on my '67 CB450, looks very period correct...
« Reply #29 on: January 16, 2023, 07:38:02 AM »
Yes, I should have saved some.
I have one from many years ago. Use it every time I change tire and tube.
https://www.amazon.com/gp/aw/d/B01M357SMJ/ref=sspa_mw_detail_1?ie=UTF8&psc=1&sp_csd=d2lkZ2V0TmFtZT1zcF9waG9uZV9kZXRhaWwp13NParams
« Last Edit: January 16, 2023, 07:42:46 AM by PeWe »
Offline newday777
« Reply #30 on: January 16, 2023, 05:09:51 PM »
I remember some had a rubber top cap.
I still have a couple in my toolbox in San Diego.....
Stu
My current rides
Prior bikes....
« Reply #31 on: January 17, 2023, 06:51:23 AM »
50 pieces.  That would be enough for all my bikes and then some!
Offline Little_Phil
« Reply #32 on: January 18, 2023, 09:07:56 AM »
Last couple of tubes I bought had the tool built into the reverse side of the plastic dust cap. Hard plastic and worked ok.
