Author Topic: Did I just screw up my top end rebuild???!!!  (Read 1742 times)
Offline justinmcgiver
« on: March 10, 2007, 12:54:00 PM »
So....
Last night durring my 12th hour in the garage I got to the point of reassembling the top end. I decided to use a tiny amount of hondabond on the mating surfaces around the cylinder base gasket as the surfaces were not perfect. Yes I have read all the posts about gasket sealer and I was sure to use it extremely sparingly. Everything went together smoothly...got the cylinder on easily. Then the head went on no problem. At this point I realized I had left the torque specs and tightening sequence at home so I decided to call it quits without tightening down the head. The head and cylinder were tapped down snugly but not tightened down.
My worry is this: Is the Hondabond, having not been compressed completely against the mating surfaces,  going to dry in a way that is going to compromise the seal when I do go back and tighten everything down? I only used the absolute smallest amount I could get on there and only in the areas where the mating surfaces were not perfect. Do I need to pull everything back apart and start again or am I just totally overthinking this whole thing. I'm totally stressing out over this bike right now! I really don't want to get this thing back together and have it still blow oil all over me!
What do you guys think?
'74 CB750 K4 - Lake Placid, New York USA
Offline Jim F
  • go baby go
Re: Did I just screw up my top end rebuild???!!!
« Reply #1 on: March 10, 2007, 03:08:48 PM »
If its a very fine coat of gasket material then I would say don't worry
but
to be safe I would start again
I have never used gasket material on the motors I have built but thats just me
my sohc and my GS 2 valve have over 180 psi cranking pressure with out blowing anything out
and they have seen red line plenty of times
good luck
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline kghost
« Reply #2 on: March 10, 2007, 03:12:32 PM »
If its the base gasket you will be fine.
If it were the head gasket I would say start again.
I would torque it down and go.
Stranger in a strange land
Offline scondon
  • Mmmm......tasty bugs
« Reply #3 on: March 10, 2007, 03:13:46 PM »
  Glad to hear I'm not the only one stressing out about their engine ;) :D
   If it were me, I would go back and check that when the cylinder and head were tapped down snuggly that they were in fact pressed against the gasket and lower case all the way around. If so, then I would torque the head down and call it good.
   I've used the Yamabond(not Hondabond) and it does not dry hard. I'm thinking that your worry may be that it may not "spread out" as it would have if you had torqued everything down while it was still "wet". This stuff dries faster in the open air so with your cylinder block covering it I would think there be enough "fluidity" left to achieve some spread. Even if there wasn't I think your ok since you applied only a very thin film.
   Just my opinion.
Hop on a Honda
« Reply #4 on: March 10, 2007, 04:50:30 PM »
A very thin film of that goo will be enough but too much will squeeze into the cramkcase. IF The goo was too thick the only thing that may happen is that it will decrease the compression ratio ever so slightly. The good goo takes quite a while to stiffen I believe it will not go hard as such.
If you have check tightened the torque values of the head before the engine installation into the frame I would say it should be OK.
After a while it would be good idea to remove the sump and check the oil pump screen for any excess goo that may have been squeezed into the innards of the engine. That is if you have been over zealous with the gasket goo.
I have seen a locating dowell in the top part of the crank case (where the block fits onto) badly fitted and still did not leak!!
Cheers
Dave
Offline chung
  • Giddy Up
    • chungfucycles.com
« Reply #5 on: March 10, 2007, 06:35:01 PM »
IMHO:
If I had snugged all the nuts then I would leave it, But If not then I would do it again.
Being a lazy old bastard, this is just the way I think:
I didn't want to do it the first time, I sure don't want to do it twice. Pulling the jug isn't as hard as pulling the motor and then....
Member#2815
1971/76 CB750 Hack @970cc,
1975 CG750K
1970 CB350,
1972 YDS7, 250
1972 YR5, 350
1977 RD400,
1978 Piaggio Grande/Batavas HS50 Special
1981 XS650 Special II
