Author Topic: 1975 750K front wheel lacing  (Read 1056 times)
Offline katman
« on: January 29, 2023, 08:22:33 AM »
Okay, After many attempts, and watching videos, I'll still must be doing something wrong. Any suggestions from anyone who has done this before
Offline denward17
Re: 1975 750K front wheel lacing
« Reply #1 on: January 29, 2023, 09:36:56 AM »
I recently did mine about 2 months ago.  Hopefully you took good pictures before you started.
I recommend taking them all out and starting over.
Here is a couple of pics of mine, may help.
« Last Edit: January 29, 2023, 09:43:14 AM by denward17 »
Offline denward17
« Reply #2 on: January 29, 2023, 09:40:15 AM »
more:
Offline newday777
« Reply #3 on: January 29, 2023, 10:04:25 AM »
Your spacing lots right, just need to rotate the rim and hub to get the angles steeper, which will pull the nipples to the rim.(you have shallow angles compared to denward17 pictures)
Stu
My current rides
Prior bikes....
Offline katman
« Reply #4 on: January 30, 2023, 05:45:56 AM »
Okay great, and thanks for the pics
« Reply #5 on: February 04, 2023, 10:36:51 AM »
 Study the dimples and you can see they are angled innie and outie and left and right. That and the rub marks on the hub may give the clues you need. Nearly everybody that laced one has had a false start or two.
« Last Edit: February 06, 2023, 10:37:07 AM by Don R »
Offline katman
« Reply #6 on: February 06, 2023, 07:11:57 AM »
Got it, Thanks for the help guys. Now on to the rear.
« Reply #7 on: February 06, 2023, 10:40:15 AM »
 I've used a swingarm for a truing stand but later bought a cheap wheel balancer stand off of ebay, it's easy to make it a truing stand also, a threaded bolt, a couple nuts, a vacuum cap for a softener on the end of the pointer and you're in business.
