Author Topic: Rear Brake Drum Placement  (Read 4564 times)
Offline Ellz10
  • ZZ
  • Knowledge is Power
« on: February 24, 2023, 01:42:43 PM »
1977 Honda CB750 K
So I had to fab up my own rear brake strap due to going with a bigger tire. However the issue I'm running into, or rather the question I have is whether or not the placement of the rear drum has to be in an exact spot?
Obviously with the rear axle nut loose, I can spin the whole thing around and around, but once I tighten the nut the whole thing stops moving. In regards to the brake arm (the dots match up) and whole assembly, does it matter where it's placed?
« Last Edit: February 24, 2023, 01:52:55 PM by Ellz10 »
Offline denward17
Re: Rear Brake Drum Placement
« Reply #1 on: February 24, 2023, 03:17:20 PM »
Good question, and I don't really know for sure.
But seems to me if the brake arm is connected it doesn't matter where it is.  Just needs to be long enough for wheel movement fore and aft for chain adjustment.
Offline Mikey G.
« Reply #2 on: February 24, 2023, 03:29:42 PM »
Nope, doesn't really matter.  It sort of rotates around a little bit every time the rear swingarm moves, so exact placement isnt super-critical.  Just don't point it straight forward so it's got no way to move and you'll be fine.
-1970 CB750 K0
-1980 KZ1300
-1976 Yellow GL1000
-1965 CA77 "Dream"
-1997 Valkyrie
-1975 Velosolex
Offline Ellz10
  • ZZ
« Reply #3 on: February 24, 2023, 04:33:53 PM »
Awesome, thanks so much y'all! Appreciate it!
« Reply #4 on: February 24, 2023, 04:41:27 PM »
Careful..... from a physical “pull” perspective, the brake lever (on the hub) should be in the “7 o’clock” position, and not be pulled past the “6 o’clock” position when full on. Any further than that and the force is being used to pull DOWN and not ROTATE the crank.
Offline Ellz10
  • ZZ
« Reply #5 on: February 24, 2023, 05:01:13 PM »
I'm at work right now, but when I get home I'll drop it down and see where it sits. I think I'll be needing to rotate the brake arm off it's matching dot point. No harm there I don't believe though. I'll update this a bit later.
« Last Edit: February 24, 2023, 05:29:22 PM by Ellz10 »
« Reply #6 on: February 24, 2023, 05:01:28 PM »
  What he ^ said and don't forget the brake pull rod also has to reach and make its travel.
  Remember, that strut holds your life in its hands, I've got a 750 with a 16" X 5" wide M&H slick and a slightly bent stock brake strut.
Offline Ellz10
  • ZZ
« Reply #7 on: February 24, 2023, 05:08:30 PM »
When you say "brake pull rod", you're referring to the rod that attaches to the brake arm, correct?
Offline Ellz10
  • ZZ
« Reply #8 on: February 24, 2023, 05:27:38 PM »
5" wide RIM??
« Reply #9 on: February 24, 2023, 05:42:58 PM »
 Make sure wherever the brake strap ends up lining up be sure to use the bolt that has the hole in it for adding a safety cotter or other pin to keep the nut from spinning off. Make sure that clears the tire also. Bad news if the strap comes unfastened. Wish I had a bike here but it seems at either one end of that strap or both the nut is never clamped super tight because the bolt has a shoulder on it to allow a little play.
Offline Ellz10
  • ZZ
« Reply #10 on: February 24, 2023, 06:39:09 PM »
Absolutely! Both bolts on either end have cotter pins that go in! I made sure to fab up a strap that would clear the tire.
I've never heard or read anywhere that the nut shouldn't be screwed on tight? Can you elaborate on that for me so I can understand please!
« Reply #11 on: February 24, 2023, 06:57:01 PM »
The swing arm has to be able to move freely. Hopefully somebody that has been down in that area lately can give more insight or I may be completely wrong  ;D Bad part about not having my bikes handy at home.
« Last Edit: February 24, 2023, 07:00:59 PM by ekpent »
« Reply #12 on: February 24, 2023, 07:05:22 PM »
Screwed on tight it will want to capture the steel arm rather than allow it to pivot as designed. It needs to be able to rotate to function.
Offline Ellz10
  • ZZ
« Reply #13 on: February 24, 2023, 07:46:20 PM »
So it's alright to leave the nut barely snug/loose on both sides, just so long as I remember to put the cotter pin in there? Is that about right?
Offline Mikey G.
« Reply #14 on: February 24, 2023, 08:53:20 PM »
As I remember, that bolt really should have a shoulder on it that's just barely wider than the arm and hub.  This lets you tighten the nut tight to the bolt, not to the arm.  This allows the free pivot of the arm, while also letting the nut get tight enough to it doesn't spin off.
Even with the cotter pin I'd be very wary of not getting that nut fully secure.
-1970 CB750 K0
-1980 KZ1300
-1976 Yellow GL1000
-1965 CA77 "Dream"
-1997 Valkyrie
-1975 Velosolex
Offline Ellz10
  • ZZ
« Reply #15 on: February 24, 2023, 10:06:36 PM »
Here's the lineup. On the left is for the hub and on the right is for where it bolts up to the swingarm
Offline Ellz10
  • ZZ
« Reply #16 on: February 24, 2023, 10:09:44 PM »
Well I did it folks! Got her all dialed in and we've got  braking power. My mistake was not having the rear hub steady when I was spinning the tire and applying the brake.
Going to center some holes to be drilled out of the center of the brake strap I made to reduce a little weight. I'll probably just remake the whole thing in aluminum instead. At least now I know it works as intended.
Many thanks to you all!
« Reply #17 on: February 24, 2023, 11:46:06 PM »
+1
« Reply #18 on: February 25, 2023, 12:26:54 AM »
In UK the bike should fail MOT(annual inspection) if the angle between pull rod and operating arm exceeds 90 degrees
« Reply #19 on: February 25, 2023, 12:51:18 AM »
Which bolt are you asking about? I'm confused as some answers seem to be about the swing arm, others the axle bolt, and yet others about the brake backing plate rod/arm.
« Reply #20 on: February 25, 2023, 02:37:42 AM »
You've made your brake stay too short.
Too much angle of the hub stay mount.
Your picture is 1st.
Offline Ellz10
  • ZZ
« Reply #21 on: February 25, 2023, 08:27:21 AM »
Interesting.
So if you're looking at the picture I posted with my last reply last night, are you saying the brake arm should be pointing more to the right (towards the front) or left (towards the back)?
Offline Ellz10
  • ZZ
« Reply #22 on: February 25, 2023, 08:29:01 AM »
I'm not asking about any bolts really lol. I just was showing a pic of the 2 bolts that that Lucien guy was talking about, that's all.
Offline Ellz10
  • ZZ
« Reply #23 on: February 25, 2023, 08:39:58 AM »
Okayy... so then what is the correct angle?
I keep getting different answers from different people and have to switch up the brake stay. With the bike sitting on the lift without the tire hanging down, the brake arm is at a 6:30 position. Very close to the 7 o'clock position BenelliSEI had warned of.
So I suppose I'm lost as to the correct place for everything there doesn't seem to be a concrete explanation.
« Reply #24 on: February 25, 2023, 09:28:53 AM »
Looking at your last lift picture, I think you are OK on our angles.
