Author Topic: CB550 stuck swingarm and rusty fender  (Read 1198 times)
Offline Teddyhoeg1982
« on: March 15, 2023, 02:20:39 PM »
Got my frame powdercoated and installed new brass bushing. I reused the other parts of the axle for the swingarm. When I tightened the axle bolt the swingarm got very tight. Suggestions What i should look for when i take it apart tomorrow?
Also I found a used rear fender where the Chrome is Ok, but is very rusty on the underside. Any experience how to remove the rust and treat the surface so it could avoid to develop further?
Online MauiK3
Re: CB550 stuck swingarm and rusty fender
« Reply #1 on: March 15, 2023, 03:14:56 PM »
One slow but safe way to de-rust is electrolysis. There are many YouTube videos. Put pure water in a bucket, add some sodium carbonate (Washing Soda), put the fender in the bucket,  hook a battery charger to a piece of re-bar (+) and the fender (-) and wait. Rust will go away. After it’s clean enough I would coat the inside of the fender to slow down the return of rust.
Kind of fun to watch…..a little.
Offline ozm29c
« Reply #2 on: March 15, 2023, 04:58:00 PM »
Teddyhoeg,
The attached photos show how I restored my rear fender. I am not saying that its the way to go for you but it worked for me.
Tape (rubberised tape or equivalent) up the chrome work, glass bead blast the underside, etch prime and then a top coat.
« Reply #3 on: March 15, 2023, 05:46:59 PM »
 I may have had a couple beers but that swingarm appears to be upside down.
« Reply #4 on: March 15, 2023, 06:22:15 PM »
Haha! Not too many to take off your eye for details…
« Reply #5 on: March 15, 2023, 06:26:47 PM »
It is upside down. The shock bushings need to be on the top to be of any use......
« Last Edit: March 15, 2023, 07:02:52 PM by newday777 »
« Reply #6 on: March 15, 2023, 07:02:14 PM »
As to the rusty fender, get some gel rust remover. Coat the  rust and cover it with plastic wrap to keep the gel from drying out. Remove the plastic in the time frame and scrub the rust with a brass brush, then rinse with water. Dry the fender with a clean rag. As said above, coat it with a good rust retarding paint.
