Author Topic: K8 Air Box Questions  (Read 593 times)
Offline Rosinante
  • All Generalizations are False
« on: April 11, 2023, 04:34:25 PM »
I am having trouble fitting this air box, and rubber hoses which connect to the carbs, onto this bike.  I had them on, but at least one of the hose clamps was not really in place.  Now, after reading, it seems the hoses for the K7-K8 carbs are different from the earlier ones.  Bigger diameter, I think.  And so....I am ready to order the correct hoses and clamps.  But now I am not sure they will fit this air box.  See what HondaMan told us in 2011 below with underlining added.
My question:  How can I tell if my air box is correct - or incorrect - for my K8?  I find no part numbers on this air box.  I *think* the hoses I have (and certainly the clamps) are incorrect for this bike.  Clamps certainly are too small.  Hoses sort of fit, but they are very tired.  See attached pics.  This is the only writing I can find on this air box.  Also, I wonder if the earlier bikes' air boxes had this large-ish air hose connection on the tops.  This connects to a gizmo (technical term) under the battery box that also connects to the valve cover.
It would be great to have a parts list for this bike, or these CB750s.  And a complete set of exploded diagrams.  ;)
Here is what HondaMan said in 2011:
Keep these things in mind when kitbashing parts:
1. The "K" engine carb hoses (K0-K6) are longer than the ones on the 1976 and later bikes.
2. The airboxes on the 1976 and later bikes have shorter hoses to the carbs than the K0-K6 airboxes, and they also have a wider mouth at the carbs if the "F" engine had PD carbs. If the "F" engine had 7A carbs, they are the same dimensions as the earlier K0-K6 carbs (same bodies), but these were just on the F0-F1 bikes.
3. The F2/3/K7/8 airboxes have bigger holes where the hoses fit, too, so the K0-K6/F0/F1 hoses don't fit those airboxes. The F2/3/K7/8 airbox hoses are also shorter than the earlier ones.
So, for example...if you have a K1-F1 engine with the stock carb hoses between the head and carbs, and are using the early-style carbs (with ID numbers like 657A, 657B, or 7A stamped on them), then use the K1-K6 style airbox and all will fit fine, even in the frame mounts.
However: the airbox hoses do shrink from the years. They are soft polyethylene-neoprene, which shrinks about 1% of its length and diameter every 12 months.
1978 CB750K
Offline denward17
Re: K8 Air Box Questions
« Reply #1 on: April 11, 2023, 04:56:33 PM »
Mine has the same numbers(1978 K model).
I don't know how to answer your questions excepts, I purchased new air horns(Honda) that fit into the air box and they go in a specific way.
I had no problems getting the back of the carbs in the airhorns.  I think I purchased the new carb holders from vintagecb750, and they seem to fit nicely as well.
Offline Rosinante
« Reply #2 on: April 11, 2023, 04:59:31 PM »
That is helpful.  Thank you.  I have the hoses and clamps in my vintagecb750 shopping cart.  Hoping for additional input.
1978 CB750K
Offline Rosinante
« Reply #3 on: April 19, 2023, 10:13:26 AM »
Update:
Here are two pics of the rubber hose that connects the air box to the carbs.  Dennis says they go "in a specific way."  The air box is has a tilted-back surface against which these are mounted.  IOW this surface is not parallel to the mouths of the carbs.  In one of the pics, you can see a flat spot.  This faced downward, so that the flat spot corresponds with the seam in the two-piece air box.
Question:
There is a small hole at the top of the air box.  Air getting sucked into this hole would be post-filter.  Inside the center of the upper air box, where this hole would enter, there is a triangular metal thingie.    -     Also near the tiny hole is a bracket.  This bracket seems to hold the hose which is the carburetor air vent hose.  This hose simply terminated behind the air box, under the battery, which is a sort of "quiet" area in terms of environmental air pressure.  After reading HondaMan's description of the importance of various air pressures involved in carburetor function, I wonder what (if anything) goes in this little hole at the top of the air box.  I wonder if the carb air vent is supposed to somehow plug into this hole.  I hope not.  I hope for some input and guidance here.
« Last Edit: April 19, 2023, 10:15:51 AM by Rosinante »
1978 CB750K
Offline denward17
« Reply #4 on: April 19, 2023, 11:27:41 AM »
Pretty sure mine does not have that hole.  I don't think it is suppose to be there.
Online Stev-o
« Reply #5 on: April 19, 2023, 02:16:02 PM »
Here is a link to the parts fiche for your bike, bookmark it. It can be very handy to identify parts and parts numbers and using those numbers to find/order parts.
https://www.partzilla.com/catalog/honda/motorcycle/1978/cb750k-a-750-four-k/air-cleaner
