Author Topic: Maybe one more.....  (Read 5446 times)
Offline britman
Maybe one more.....
« on: April 23, 2023, 04:40:37 PM »
Driving 400 hundred miles Wednesday the 26th to look at one, yes it is a 750K.  I need to get the Yamaha smell out of my garage after doing two in a row.  Will post if it comes home........
Re: Maybe one more.....
« Reply #1 on: April 23, 2023, 04:48:52 PM »
You’re sicker then most! Good luck.
Offline britman
« Reply #2 on: April 26, 2023, 02:11:05 PM »
Yes I know it is rough but it is the cheapest one I have bought in a long time and it runs.  The seller got it running just enough to post it for sale and from looking at the condition of the carbs and house electrical wire used for the ground and solenoid hot wire I am amazed it fired at all.  It has not been on the road since 1995 and was sitting under a pole barn parked for all of those years.  The clock shows a little over 11k but who knows, tank is rusty but solid, mice have had numerous buffets on the seat foam and the title is long gone.  It will take awhile to obtain a title in Virginia using the Abandoned Vehicle Process but it is going to be awhile before it hits the lift anyway.  All of the lights, horn, and starter work great, so there is some good, it is just nice to have another K back in the garage..... (year is 73 with the correct frame and motor numbers)
« Reply #3 on: April 26, 2023, 03:54:26 PM »
You’ve got some project work there! It will be fun to watch the transition. Congrats.
Offline britman
« Reply #4 on: May 08, 2023, 07:51:55 AM »
It is still in the back shed, can't put it on the lift till the Yamaha is sold and sill waiting on the title for that to return from DMV.  With a new Puppy thrown into the mix, life has been somewhat hectic as of late.  I do have the oil draining, just as I thought the seller topped off the old with some new, overall not bad, no debris or bits that I can see.  I did power wash it but it still looks like a 73K that has been sitting for 25 years.  Wheels and seat are going to be a bear, but nothing like a good challenge. I am on the fence with the seat, foam is all but gone and I see where you can buy the foam already shaped but it is pricey, with that and a new cover thrown in you can almost buy a re-po saddle for the same money.  Will do a little more research, there is plenty of time on this one....
Online Stev-o
« Reply #5 on: May 08, 2023, 08:57:47 AM »
Some may say you are a gluten for punishment!  But some of us have seen worse, subscribed to see your majic on the transformation...
Offline britman
« Reply #6 on: May 13, 2023, 02:49:51 PM »
Caswell in the tank, on the lift, carbs and exhaust pulled and kits arrived in the mail today, guess it is underway.....
« Reply #7 on: May 13, 2023, 03:22:45 PM »
That is the biggest rear shock relocation bracket I've seen!
« Reply #8 on: May 13, 2023, 04:43:07 PM »
That is a seriously ugly piece!
« Reply #9 on: May 13, 2023, 06:39:33 PM »
Totally John
Offline Johnie
« Reply #10 on: May 13, 2023, 06:50:57 PM »
It's as we say, "a diamond in the rough." I think it has a lot of potential. Good luck with it.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline britman
« Reply #11 on: May 15, 2023, 02:42:18 PM »
Why thank you.....I must have 5 or 6 of these lowering kits in my cache, but you are right this one is a heavy duty model. I have no idea why I keep them.....
Anyone want to know the greatest free therapy you can administer to one's self????? Spent an hour or two cleaning "Mud Dauber" nests out of cylinder fins...........
« Reply #12 on: May 15, 2023, 05:02:40 PM »
Following along, the transformation will be extraordinary, I’m sure!
Offline britman
« Reply #13 on: May 15, 2023, 06:48:46 PM »
I also changed the oil pan gasket this afternoon because it was weeping a bit.  I was amazed how clean the bottom of the pan and screen appeared.  Hoping for a good strong motor.  I will  do a compression test after adjusting the valves.  Also when I pulled the oil filter the metal washer was missing, I have not seen one in place in any project I have done, where do they all go?????
« Reply #14 on: May 16, 2023, 02:10:22 AM »
Stuck on so many thrown away filters by many unsuspecting newbies......and maybe some forgetful old timers
Offline britman
« Reply #15 on: May 27, 2023, 11:37:25 AM »
A little elbow grease applied to the motor and the rebuilt carbs bolted back on.  I was able to use the old boots after a few day soak in wintergreen oil and alcohol. Carb kits were from Vintage 750 which I am starting to use more and more.  Ship fast, very good product line.  I ran a quick compression test on 1 and 4 because they were easy to get too, 150 PSI on both jugs, that made me
real happy. I have two sets of exhaust to choose from, the shorty two into two set up which came with the bike, or a period set of 4 into 4's with baffles.  Both cleaned up fairly well.  A new set of stock style handle bars are on the way, so probably going to have to shorten some wires and a new brake line. Who ever installed the tall set did take the time to run the wires internally, damnit.  Still a long way to go and a ton of rust and dirt to battle, but getting there....
« Reply #16 on: May 27, 2023, 02:17:56 PM »
Looking good!
« Reply #17 on: May 27, 2023, 04:28:44 PM »
Impressive, as always!
Offline britman
« Reply #18 on: June 01, 2023, 05:49:19 PM »
You find a set of old vintage 4 into 4 pipes with baffles on FB.  They have been there for a number of weeks so even with shipping they are bought at a decent price.  When they arrive fitment is great "EXCEPT" there is no rear mounting brackets and they would probably be fine with just the spout clamps but there is some movement.  You spend a few hours looking for some type of ready made bolt on clamp but it finally comes down to you have to make something.  Digging through your old parts bin produces two bolt together three piece chrome 1 1/2 inch clamps, left over from long forgotten project and probably not used because in general bolt together clamps tend to be problematic to say the least.  Some aluminum strips are located hidden behind the stand up tool box and the thinking process begins.  After the clamps are disassembled and the cut down, the drilling and tapping starts, kind of assembling on the fly. You find most of your drill bits are duller than an accountant convention, (yes I can say that because my Daughter is a CPA) and your tap and die set is of course missing the fine thread 1/4 tap you need after spending $14 bucks for the stainless button head bolts and nuts.  After multiple trips to the hardware store, several failed designs, some new tools thrown in for good measure, and what I thought would be a couple hour job turning into  most of the day, damnit, I have exhaust pipe clamps. You know what, I did curse some, but I enjoyed every minute of the process.  It is a good feeling to make your own, but if you add in the hardware store bill, gas, and my time, the clamps probably cost a hell of a lot more than the ones on Ebay.
Next up, researching how to do block off the chain oiler, sprockets and drive change arrived today and I had forgotten about that feature on the earlier models.  Probably have to make that too...
« Reply #19 on: June 01, 2023, 06:52:56 PM »
Wow! I had to make something similar when I refitted the original Amen foot pegs to the Carlini Chopper. Spent a day making a small bit that had been lost over the years….
Enjoy the satisfaction of a job well done. Lots of people on here “get it”. Looks great!
« Reply #20 on: June 01, 2023, 06:55:19 PM »
P.S. If the chain oiler is fully intact, you should be able to just turn it all the way OFF.
Offline britman
« Reply #21 on: June 06, 2023, 08:49:24 AM »
Fresh Virginia title issued this morning.  The Abandoned Vehicle Process here is really not all that involved or costly to obtain a title, it just takes a lot of time for the process to run it's course.
« Reply #22 on: June 06, 2023, 09:39:47 AM »
Good for you! I had a bad experience years ago, so now that is “first step”.
Offline britman
« Reply #23 on: June 08, 2023, 05:34:03 PM »
Want a good buy-rear shocks from Scrambler Cycle.   $55 bucks for the set and good quality.  I have run a set on my 74K for a couple of years now and the ride is good and they have held up well.
I also purchased a seat from SCI on Ebay for $198 bucks and for the money the quality can't be beat. By the time you purchase a good cover and the padding, I think you are coming out ahead with the compete seat. Again there is one on my personal bike and it has held up great.  I posted the link, take a look at workers in the ad.....
 https://www.ebay.com/itm/373369732057?fits=Model%3ACB750K%7CMake%3AHonda&hash=item56ee91fbd9:g:D-EAAOSwpLVcJPfq&amdata=enc%3AAQAIAAAA4LPvbFOYAyTZeUmHNILXzTZPnDnmk9zyNhaDUjYQt6IX0HrOkpqlUf71P%2Fp6aorQaWHt3g%2Ffl%2FXEBr2XURt%2B4kwj0VCIo5E6%2BdN0QpEW2mzOTFO4nFNisqrWFYBrfnVPteJA%2BQJIqPkoCU7gMy4fzgLCaD7rDJktMafjQMArwX6MxKCtHJ0ZCVljEJ6Axmhjq0ojRKVMvN5cyM0aoiAyosHMVEC3%2BACnJf7sduiqj%2Br%2FfMrtoC8sbqC7hQHa8emPOht8zFyD8ZWJtG7Jz6zfimgDgUE9e74NQ1vj6wmUK92F%7Ctkp%3ABFBMysz92JNi
« Reply #24 on: June 08, 2023, 05:57:56 PM »
I like the tire! Planning on hitting the desert? SCI is local for me. They have some great deals and even less if I pick it up……
P.S. None of those girls are there when I drop in!
« Last Edit: June 08, 2023, 05:59:39 PM by BenelliSEI »
