Author Topic: A tiny voltmeter with a separate mount near my speedo/tach. ??  (Read 1557 times)
Online grcamna2
Has anyone here used a very small voltmeter with it's own separate 'pod' which can be mounted somewhere between my speedo/tach that's accurate,vibration-resistant & weatherproof ?  Round is preferable.
I had chrome SW mechanical analog gauges in automobiles back in the 70's which I 'Loved'  ;) 8) but they would be way too big.
« Last Edit: May 29, 2023, 12:07:31 PM by grcamna2 »
Offline Kevin
Re: A tiny voltmeter with a separate mount near my speedo/tach. ??
« Reply #1 on: May 29, 2023, 10:45:53 AM »
I use the Yoshimura temp gauge, you can toggle it to monitor voltage.
The exchange rate is pretty good right now, you can buy one from Webike.
Sent from my SM-S908U1 using Tapatalk
A couple of 400F's and a
'98 Suzuki Intruder VS1400 ~ for long rides
Online grcamna2
« Reply #2 on: May 29, 2023, 10:55:41 AM »
Do you hook this temp. gauge to your cyl. head or exh. ?
Offline Kevin
« Reply #3 on: May 29, 2023, 10:59:17 AM »
The temp gauge hooks up to a special oil drain bolt that is a sensor.
Online grcamna2
« Reply #4 on: May 29, 2023, 11:01:56 AM »
Please post a link  :)
Offline Kevin
« Reply #5 on: May 29, 2023, 11:13:49 AM »
https://japan.webike.net/products/21365230.html
https://japan.webike.net/products/21844484.html
You would need to verify your oil drain bolt thread pitch.
Offline willbird
« Reply #6 on: June 01, 2023, 07:54:16 AM »
That would be super cool if it did temp, time of day, and volts, and you could set up to just scroll  between the 3 functions :-).
Offline Kevin
« Reply #7 on: June 01, 2023, 08:08:25 AM »
Here's a video I took a couple of years ago of my bike. At the end of the video, you can see the temp meter.
The video was taken before the carbs were tuned.
« Last Edit: June 01, 2023, 08:39:01 AM by Don R »
Online grcamna2
« Reply #10 on: June 01, 2023, 03:11:49 PM »
I found a little digital voltmeter with power ports built in on ebay. It was cheap but is still going after a couple years.  This one needs a mount made for it.
https://www.ebay.com/itm/394522130363?hash=item5bdb59f7bb:g:wQMAAOSwl01kGAf8&amdata=enc%3AAQAIAAAA0Dk3GAS9IWe%2BWxMRWpXB8mRyTJpimhZW7VEc79VE8tFBkHrHnvEIE5HoV49sK5uUH1aToI6CZT0mIXN4Nczw0SPsnz9fg1OJs0QATosGPzXL%2BT5f8Kem%2BWtueNkZXNvzS5slYASbgszKGQvlr3HEzsFOY06RNDlFfZulmK8RjV4bVNttC%2FLQG5rp14c2u7h%2FOQPNrBcIrG3hlBUblQMrb%2B96XsAsRJe2yl8aAYDqLtS0D%2FGNM88sc%2F2gU6PetWg42W802oYrsWK4JJkyz86bYuc%3D%7Ctkp%3ABk9SR_iN2_mOYg
Does it go directly to your battery terminals with an on/off switch Don ?
I have one like Don’s (maybe even smaller) on my KLR. I wired it to the taillight feed. Cost less and still works great.
Offline Kevin D
  • SE Michigan
« Reply #11 on: June 11, 2023, 04:22:00 PM »
Same meter here, it’s fused and it’s tapped in the headlight shell to black and green. I have it wire tied to the handlebars, it’s not a show quality mount. I’m using the USB to charge my phone, and use Waze while traveling or away.
The meter is on its second season. The bike is parked inside and I do my best to not ride in the rain
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
« Reply #12 on: June 11, 2023, 05:22:00 PM »
 I wired mine through the hot wire to the windjammer, the voltage is often reading low. There's a lot of voltage loss in all that wiring, plugs and 45 year old switches. I added a relay to feed my dyna ignition.
Online grcamna2
« Reply #13 on: June 11, 2023, 05:54:14 PM »
I like the one you linked to Don.
I'm still looking for a tiny SW-style analog voltmeter;a 1.75'" w/ a little needle ??
Offline Kevin D
  • SE Michigan
« Reply #14 on: June 14, 2023, 07:28:57 AM »
Sorry, I’m a little slow getting here with these photos of my setup.
A couple years back, my older AGM battery just quit mid-ride, 50 miles away from home. I kick started it and rode it carefully home. Caught two red lights on the way, stalled at the first but not the second, phew! Later considered that a voltmeter might be a useful tool to have onboard.
Also noticed that my older phone battery was pretty low in the latter stages of rides, so I added the phone mount and charging cord.
The practical value upgrade outweighs the aesthetic value downgrade, IMHO.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
Online grcamna2
« Reply #15 on: June 14, 2023, 11:15:42 AM »
Kevin,does that voltmeter/charge port come with it's own handlebar mounting strap ?
Offline Kevin D
  • SE Michigan
« Reply #16 on: June 14, 2023, 11:58:32 AM »
No, I have used two wire ties, one around the barrel of the meter and the second around the handlebar. The meter is not going anywhere.
The body of the meter is threaded and you’re given a large nut that threads on the body, for a panel mount. Do you know the detail that relocates the ignition switch from under the tank to the handlebar clamps? A detail like that might also hold this meter, although I think the meter has a larger diameter than an ignition switch
« Last Edit: June 14, 2023, 02:14:56 PM by Kevin D »
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
Online grcamna2
« Reply #17 on: June 14, 2023, 02:38:58 PM »
Yes,it usually bolts to one of the handlebar clamp bolts.
« Reply #18 on: June 14, 2023, 06:26:25 PM »
CHEAP Chinese meter attached with 3M double stick
Offline bert96
  • past ride
« Reply #19 on: August 12, 2023, 10:34:13 AM »
Heres mine. Not tiny but i like it.
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Online grcamna2
« Reply #20 on: August 12, 2023, 12:47:35 PM »
I could probably use Velcro too.
