Author Topic: Looking for troubleshooting Help on my 76 750F  (Read 4447 times)
Offline tofan
Re: Looking for troubleshooting Help on my 76 750F
« Reply #25 on: June 07, 2023, 03:14:28 PM »
069A carbs?
Slow jet size 38? OEM?
Jet needle at position 2? (position 5 is top slot) OEM?
Carbs - 064A
Slow jet - 40
Main jet - 105
Needle - #271307 and is set in middle (3rd) position
All Keihin and all to spec
Attached images from shop manual
Although I have seen other specs on the internet. For example: https://motorcycleproject.com/text/specs_revised.html
« Last Edit: June 07, 2023, 03:49:45 PM by tofan »
1976 CB550K
1976 CB750F
1978 CB750F
Offline smee
« Reply #26 on: June 07, 2023, 03:57:12 PM »
069A carbs?
Carbs - 064A
Slow jet - 40
Main jet - 105
All Keihin's and all to spec
Here is what I use: http://www.hondachopper.com/garage/carb_specs/carb_specs.html
Could be just a tad too rich on the slow jet. Are the carbs stamped 064A or 069A?
Offline tofan
« Reply #27 on: June 07, 2023, 03:58:10 PM »
069A carbs?
Carbs - 064A
Slow jet - 40
Main jet - 105
064A
Found this interesting doc: https://www.dotheton.com/index.php?attachments/carburetor-specifications-doc.51991/  If you scroll down to page 3 there's a comment attached to the 76 CB750F that says "was 069A"
If changing the plugs and what doing what RAFster suggested doesn't help then I might try changing the slows to 38.
« Last Edit: June 07, 2023, 04:47:04 PM by tofan »
1976 CB550K
1976 CB750F
1978 CB750F
Offline grcamna2
« Reply #28 on: June 07, 2023, 05:27:41 PM »
069A carbs?
Carbs - 064A
Slow jet - 40
Main jet - 105
064A
How worn are your 4) needle jets/nozzles ?
I keep an NOS to measure with to compare with the ones I have installed;when they wear too big,it can over-juice.
I use a #1-60 drill index and carefully try each drill bit on the smooth end starting with my NOS nozzle,then compare to the used ones to see how far they're worn.
« Last Edit: June 07, 2023, 05:35:10 PM by grcamna2 »
75' CB400F/'bunch o' parts'
Offline tofan
« Reply #29 on: June 07, 2023, 05:30:43 PM »
Hmmmm... I think they looked ok? I didn't inspect them too closely and only recently got a couple NOS needles. But I can inspect them more closely the next time I open them up.
1976 CB550K
1976 CB750F
1978 CB750F
Offline smee
« Reply #30 on: June 07, 2023, 06:06:10 PM »
069A carbs?
Carbs - 064A
Slow jet - 40
Main jet - 105
064A
That is an interesting doc! Yeah, good luck and let us know how it goes for you.
Offline grcamna2
« Reply #31 on: June 07, 2023, 07:02:52 PM »
The OEM Honda 'needle sets' come with the needle and needle jet/nozzle all inside the package as a set.
« Reply #32 on: June 07, 2023, 07:41:45 PM »
069A carbs?
Carbs - 064A
Slow jet - 40
Main jet - 105
I just noticed the float level spec on the bottom pic is 26mm, or .866 inch. 26mm is actually 1.02 inch, and .866 inch is actually 22mm. I would go with the 22mm setting, as your clear tube levels are too low.
Offline Tracksnblades1
« Reply #33 on: June 07, 2023, 10:47:42 PM »
Have you verified your 105 Keihin jets are 1.05mm bore…
If you’re not the original owner…?  They may have been cleaned with a drill or wire..
My 76f runs the spark plugs on the white side of light brown with OEM 105 mains and OEM needles and clip positions.
It requires the choke to start cold…
Age Quod Agis
Offline willbird
« Reply #34 on: June 08, 2023, 04:11:54 AM »
069A carbs?
Carbs - 064A
Slow jet - 40
Main jet - 105
064A
What would wear the float needle valve body and increase the dia the fuel flows through ??
Bill
« Reply #35 on: June 08, 2023, 06:36:58 AM »
069A carbs?
Carbs - 064A
Slow jet - 40
Main jet - 105
064A
Bill
Isn’t he referring to the slide’s needle jet?
Age Quod Agis
Offline willbird
« Reply #36 on: June 08, 2023, 07:07:26 AM »
069A carbs?
Carbs - 064A
Slow jet - 40
Main jet - 105
064A
Bill
Yes I think so, my misunderstanding.
Offline grcamna2
« Reply #37 on: June 08, 2023, 09:38:51 AM »
069A carbs?
Carbs - 064A
Slow jet - 40
Main jet - 105
064A
Bill
The slide needles moving up and down do wear them after thousands of miles;the needle jets/nozzles are just soft brass.
« Last Edit: June 08, 2023, 11:09:37 AM by grcamna2 »
Offline tofan
« Reply #38 on: June 08, 2023, 10:52:39 AM »
069A carbs?
Carbs - 064A
Slow jet - 40
Main jet - 105
Huh. I will add it to my list of things to try. Good catch. That would mean this product is wrong: https://jokermachine.com/products/cb750-carb-float-level-setting-gauge
« Last Edit: June 08, 2023, 11:00:05 AM by tofan »
1976 CB550K
1976 CB750F
1978 CB750F
Offline tofan
« Reply #39 on: June 08, 2023, 10:56:19 AM »
I haven't, but I'll add it to my list of things to check.
1976 CB550K
1976 CB750F
1978 CB750F
Offline tofan
« Reply #40 on: June 08, 2023, 10:58:38 AM »
Just for reference. This is what was inside when I first opened up the carbs. Since this photo, I have thoroughly cleaned all parts and replaced the float needle and valve with NOS.
« Last Edit: June 08, 2023, 11:32:01 AM by tofan »
1976 CB550K
1976 CB750F
1978 CB750F
« Reply #41 on: June 08, 2023, 05:39:17 PM »
It is entirely possible that the problem is coming from the new intake boots. Reason: the OD of the new ones (even from Honda/Yamiya) are a little bit too small, so the OEM clamps do not usually seal the hoses at the head, even when tight. I have variously made thin strips of brass (0.010" thick) and laid them inside the boot's grooves, under the clamps, or just used different clamps like the Oetiker 050-9 (available at Aircraft Spruce) to fully solve the problem without shims or such trickery.
The OEM clamps usually are 'pulled' where the head meets the clamping bracket, making it impossible to even approach a snug fit. I always re-flatten them with [near new] needle-nose pliers and make oval-shaped washers to fit under the screw heads, as the very least fixup.
If the hose leaks at the inlet port, the mix goes rich because the airflow is slower than the engine at that intake. That carb then mixes at a slow air speed, which is richer than the actual desired mix.
« Reply #42 on: June 08, 2023, 08:00:29 PM »
Have you replaced the spark plugs yet? I had a problem once with a carb on a car that ran extremely rich, fouling the plugs. I swapped in new plugs, and they fouled within minutes. I rebuilt the carb, and brushed the carbon off the plugs, but the car still ran like crap. I even swapped a different carb on, and the engine ran the same. My roommate at the time, who was a few years older and wiser than I, came out to the barn and stated flatly "Your plugs are fouled" I told him I had replaced the original plugs, and cleaned the new ones. He said "Your plugs are fouled" I started to protest, but he interrupted me and stated once again "Your plugs are fouled", then turned and went back in the house. I gave in, bought new plugs, and the problem was solved.
The moral of this lesson is that you can fix the carb problem that caused the plugs to be fouled, but once fouled, they tend to stay fouled, even after you have corrected the original problem. Your #3 plug is wet; that cylinder wasn't even firing, so there is no way it could ever burn off the carbon.
Offline tofan
« Reply #43 on: June 09, 2023, 08:41:59 AM »
Interesting. Is there a way to verify whether there's an air leak in the intake boots?
1976 CB550K
1976 CB750F
1978 CB750F
Offline tofan
« Reply #44 on: June 09, 2023, 08:42:49 AM »
Not yet. I will hopefully have some time this weekend after the Denso plugs arrive today.
1976 CB550K
1976 CB750F
1978 CB750F
Offline newday777
« Reply #45 on: June 09, 2023, 09:58:14 AM »
Lite squirts of carb cleaner or use an unlit propane torch on, very low, so you can pin point where the leak is.
Stu
My current rides
Prior bikes....
Offline tofan
« Reply #46 on: June 10, 2023, 10:25:32 AM »
I only received one of the Denso plugs yesterday so I went ahead and installed the NGKs. It's obviously very happy, idling good at about 1100rpm with great throttle response. After I get some miles in I'll report back.
I think what RAFster said about it not liking too much idling is probably the biggest issue as I mostly take it through the town. Lots of stop and go, unfortunately. I just remembered there's a decent stretch of road with not too many cars I can push it to see how it does.
I appreciate everyone's help with this and will update you.
« Last Edit: June 10, 2023, 11:53:29 AM by tofan »
1976 CB550K
1976 CB750F
1978 CB750F
Offline grcamna2
« Reply #47 on: June 10, 2023, 10:36:18 AM »
I only received one of the Denso plugs yesterday so I went ahead and installed the NGKs. It's obviously very happy, idle running good pretty good at about 1100rpm. with great throttle response. After I get some miles in I'll report back.
The battery charge rate goes down and discharges if it idles;when I sit in traffic,I usually have a light touch on the throttle to keep the rpms(rolling between 1350-1500,sometimes I just turn off the engine if I'm sitting too long)above idle enough to keep it overcoming 'discharge mode'. I'm careful not to run the rpms up too much while sitting for fear of overheating the engine/bluing the headpipes.
I Hate red lights/sitting in traffic and watching everyone stare at their phones..  ::)
« Last Edit: June 10, 2023, 12:29:07 PM by grcamna2 »
« Reply #48 on: June 10, 2023, 11:50:59 AM »
If you have the lights on all the time switch it wont charge till about 3000 rpm
« Reply #49 on: June 10, 2023, 01:23:45 PM »
Needle in middle position.
Food for thought. The needle jet/Jet needle matched set is a -392 part number, ie -392 designates a 75/76 F part. To me this would indicate the set has a different taper for 75/76 F's.
