Hi Everyone, I've been troubleshooting my 1976 750F trying to get it run top-notch.
Symptoms:
- It seems to be running rich according to my plugs. I've attached photos of each plug that I pulled this morning.
- Here's a video of idle fluttering after a 15min ride.
https://www.dropbox.com/s/lncd3ifp2105sot/2023-06-06%2009.02.21.mov?dl=0 and someone mentioned idle should be set at 1100-1200rpm when warm. Is that correct for this bike?
- It sometimes dies when on kick-stand or when I come to a full stop.
Here are the stats and what I've done so far:
- I'm at 2,500ft elevation (Tucson, AZ)
- 25,000 miles on the clock
- 120psi on all 4 cylinders
- Everything is stock except for the Dyno S ignition, new 5ohm coils, wires and caps, and cone engineering muffler. The muffler came with previous owner and I recently installed the electronic ignition and coils.
- The carbs have recently gone through 2 sonic showers
- Drain tubes have no cracks
- Recently replaced the float needle with NOS from Ebay
- Floats set at 26mm from the gasket mating service per manual, but will check them again for accuracy this weekend.
- Oil and filters replaced. Honda GN4 10W-40 and paper filter from 4-into-1.
- Checked tappets
- Checked timing
- Air screws are about 1.25 turns out
- Bench and vacuum sync'd carbs, but I will do this again this weekend.
What am I missing?
