Author Topic: CB500k1 knocking noise at idle.  (Read 1782 times)
Offline Andey108
Re: CB500k1 knocking noise at idle.
« Reply #25 on: June 26, 2023, 02:30:29 AM »
Rubber band trick is good not bad, you use to hold theadjuster ends of the rocker arms up by connecting the arms on each cylinder with them
Ah ok, just the way you phrased it, sounded like I shouldn’t use the rubber band trick.
Like there’s a warning against it
Offline Andey108
« Reply #26 on: June 26, 2023, 02:31:48 AM »
Have you messed with your exhaust at all?
Sent from my SM-N960U using Tapatalk
Nope.
Was installed when the cylinders were done. Haven’t moved since.
Would there be a problem with the exhaust? A leak?
« Reply #27 on: June 26, 2023, 03:22:35 AM »
Like somebody famous said, England and America are two counties separated by the same language
Offline Andey108
« Reply #28 on: June 27, 2023, 12:57:04 AM »
It’s not the rocker cover making the noise… change to a spare cover.
Noise is still there… cam chain is ok tension I think.
 I listened more closely and it seems to be coming from lower down.
Can’t pinpoint exactly where.
Someone was saying it could be somewhere else??
Offline Andey108
« Reply #29 on: June 27, 2023, 07:55:13 AM »
Ok I’m second guessing my carb syncing now.
Will double check it’s synced properly.
« Reply #30 on: June 27, 2023, 10:15:14 AM »
Presuming you have already adjusted the cam chain and checked your valve clearances from earlier post about the later...
Offline Andey108
« Reply #31 on: June 27, 2023, 11:06:35 AM »
Yeah checked again today when I realised that turning it anticlockwise adds the tension.
Valves clearance is definitely correct, re-did them for the new valve cover.
But no difference in noise. Will have another look at resyncing.
« Reply #32 on: June 27, 2023, 12:32:30 PM »
Turning WHAT anticlockwise, you should be turning NOTHING on the tensioner mechanism except the locknut when tensioning chain, if yo have turned the screwdriver slot you may well have damaged the tensioner mechanism
« Reply #33 on: June 27, 2023, 02:15:30 PM »
I believe he's referring to direction he was rolling the motor over it. You roll it backwards and the slack builds on the back side of the cam chain...
« Reply #34 on: June 27, 2023, 03:48:23 PM »
No it doesnt
