Author Topic: '76 cb550 oil in the exhaust.  (Read 859 times)
Offline kerryb
  • Not a very
« on: August 04, 2023, 06:19:02 AM »
Trying to diagnose what might be letting oil into cyl #1 only.  The owner thinks it must be a failed valve stem seal.  I think it could be related to rings.  After startup, the engine slowly begins to smoke, then oil leaks from the drain hole in the #1 exhaust.  I suppose the first test would be compression and leakdown test.  Would a failed head gasket also be a likely culprit.  I may want to buy this bike,  so knowing what to fix first would be a plus.
Suggestions of test ideas welcome.
p.s. 10,000 original miles, all stock parts.
Offline denward17
Re: '76 cb550 oil in the exhaust.
« Reply #1 on: August 04, 2023, 06:38:46 AM »
Whatever it is, just know that at least the head has to come off to inspect, to either replace valves/vavle guides, seals or whatever.
Once the head is off, you have to inspect cylinders/pistons/rings.
Oil in the cylinder is coming from rings or valve guides or valve guide seals or o-rings between head/cylinder.
« Last Edit: August 04, 2023, 09:12:02 AM by denward17 »
« Reply #2 on: August 04, 2023, 06:43:29 AM »
That is where I would put my money.
Offline kerryb
  • Not a very
« Reply #3 on: August 04, 2023, 07:18:41 AM »
Thanks for the replies gentlemen,  I'll start a thread when the engine repair begins.
« Reply #4 on: August 04, 2023, 07:33:17 AM »
Hold on now!  How long has the bike been sitting?  With low mileage low, the bike can't have been used for long or often.  Has the owner been lubeing cylinders for storage?  Are or were the rings stuck?  Is it really oil?  I have seen where it takes around 100 miles to get all that crap burnt out of the pipe.  If your engine is not broke, please don't fix it.  Everyone seems to think they can build a better engine than Honda did in the first place with a $25 cylinder hone, some rings, and a clymer manual.
« Reply #5 on: August 04, 2023, 07:48:59 AM »
Stuck rings is my guess with the minimal information given
Is this a bike that was sitting with gas left in it? How long?
« Reply #6 on: August 04, 2023, 09:49:58 AM »
Agree on that and make sure that cylinder is not flooding out and its a mixture of gas and carbon deposits.  Is the smoke a heavy blue or more of a black color ?  White would be water condensation.
Offline kerryb
  • Not a very
« Reply #7 on: August 04, 2023, 12:05:31 PM »
I was thinking about stuck rings , while we are brainstorming this   it was sitting for awhile, smoke is more light blue than black
I don't want to pull it apart, so I'll try everything else first.  If a carb is overflowing to produce black smoke, then this could be cleared up with just carb work and run time.  That would be nice, but I need to be prepared for the worst!
« Reply #8 on: August 04, 2023, 02:04:22 PM »
Put a 50/50 mixture of acetone and Marvel Mystery Oil in the cylinders to help free up the rings, for a week, every day move the kick start a little bit to change positions of the rings and pistons(leave plugs loose in the head to release pressure as you kick it. At the end of the week pull the plugs, kill switch off, hit the starter to expell the mix, the run it easy outside as it'll smoke, then take a short 20 mile easy ride to work the rings free. Let it cool, then run another easy 20 miles. Report back. )
Offline kerryb
  • Not a very
« Reply #9 on: August 04, 2023, 10:07:12 PM »
[/quote]
That's a good idea, but before I can report back, I need to own it, register it, & get insurance, & go through the carbs (clear tube test).  So it will be a bit...
Thank you all for the head srart.
