Author Topic: What's a real strong chrome cleaner ?  (Read 1866 times)
Offline grcamna2
« on: October 04, 2023, 09:52:27 PM »
Hi,I've got good chrome on a set of pipes but they haven't been wiped-down/cleaned in decades & there's surface rust.
I just purchased them and want to clean them real good before installing them.
I have used Never Dull(a type of wadded-up stuff that looks a lot like fiberglass insulation)and that worked good.
 I'd like a stronger liquid type similar to Dupont Chrome polish from the late 70's:that good product isn't available anymore. The strong stuff with some 'tooth' to it if possible.  thanks,Bill
75' CB400F/'bunch o' parts'
Offline Alan F.
Re: What's a real strong chrome cleaner ?
« Reply #1 on: October 04, 2023, 10:57:24 PM »
I've used Mothers, and Turtle Wax makes one too.
« Reply #2 on: October 04, 2023, 11:05:08 PM »
Yeah...turtle wax is good I used mine all up.  Now I got Brasso.  Works good too, maybe a little stronger cleaning action with a stronger ammonia smell.  I pour it on to 0000 steel wool and scrub away.
Offline Sw1ssdude
« Reply #3 on: October 05, 2023, 12:03:45 AM »
Use those soapy 0000-steel wool pads from a hardware store (oven cleaner pads), they will clean chrome real nice without leaving a scratch. just soak them in water and go at it, with light to medium pressure.
also works well on aluminium (aluminum?), to knock down white oxidation, but on soft aluminium, brass, or paint there is more abrasion involved, even though its still minuscule..
but for refreshing blind or dull chrome, and knocking down light rust, steel wool pads are great!
It's not a big motorcycle, just a groovy little motorbike...
Offline grcamna2
« Reply #4 on: October 05, 2023, 12:14:57 AM »
The SOS steel wool pads I've seen all look more coarse than the #0000 ultra fine 'un-soaped' steel wool pads.
Where do you purchase #0000 soapy steel wool pads ?
Offline grcamna2
« Reply #5 on: October 05, 2023, 12:17:45 AM »
Sean,it's Turtle Wax pour-on liquid chrome cleaner,do you have a product number of the stuff that works best for you ?
I just wonder about the stuff they sell here in Ca.,might be weak.
Offline Scott S
« Reply #6 on: October 05, 2023, 03:05:37 AM »
 0000 steel wool and Windex, followed by a good chrome polish, like the ones mentioned above. You can use the chrome polish/steel wool combo together as well. I finish up with chrome polish and a soft rag.
 I get 0000 steel wool from Lowe's or the hardware store.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #7 on: October 05, 2023, 07:20:45 AM »
I've used 000 steel wool and WD-40 to remove surface rust, works well.
Simichrome is about the best polish out there...
« Reply #8 on: October 05, 2023, 08:31:59 AM »
no, sorry...pretty sure I just bought it at the hardware store
Offline carnivorous chicken
« Reply #9 on: October 05, 2023, 08:38:01 AM »
Easy Off oven cleaner. Spray and a wait a little.
Offline grcamna2
« Reply #10 on: October 05, 2023, 09:37:38 AM »
Scott,I have #0000 steel wool pads w/o soap;I love the way they polish with no scratches in the chrome later.
I want to get a very strong liquid chrome cleaner to use together with them;Turtle Wax chrome cleaner sounds like what's recommended.
« Reply #11 on: October 05, 2023, 12:27:08 PM »
Appears like they have a couple types...
https://www.google.com/search?q=Turtle+Wax+chrome+cleaner&rlz=1C1SQJL_enUS786US786&sourceid=chrome&ie=UTF-8
Offline Kelly E
  • Geriatric Hooligan
« Reply #12 on: October 05, 2023, 03:45:50 PM »
Quick -Glo chrome cleaner/rust remover. It works great and it's made in Louisiana.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline grcamna2
« Reply #13 on: October 05, 2023, 03:55:07 PM »
I watched a review,seemed ok.
Offline BenelliSEI
  • 1969 cb750
« Reply #14 on: October 05, 2023, 04:39:28 PM »
I use a mix of Autosol and Mothers Chrome Polish. Does a fine job, right after the 0000 soap pads.
Online Don R
« Reply #15 on: October 05, 2023, 05:34:48 PM »
 Turtle wax chrome cleaner sometimes with either 0000 steel wool or aluminum foil.
Offline grcamna2
« Reply #16 on: October 05, 2023, 05:40:38 PM »
I've also used a small blue-handle brass bristle welder's brush on heavy deposits a few times,just to remove the crusty rust;it didn't leave scratches.  I appreciate the feedback.
Offline jgger
« Reply #17 on: October 05, 2023, 06:18:09 PM »
This stuff is great,  I have used it since the late 60's
Kelly E, if you use enough of that other bottle, even rusted through pipes start to look good!
« Reply #18 on: October 05, 2023, 06:42:20 PM »
+1 (x3). Best stuff.
If used on aluminum (like the front forks) it also seals the surface: I used in on my fork lowers in 1972 (after removing the varnish from Honda) and they still look new, no pitting. Works on clutch/brake levers, wheels, spokes too.
Offline Kelly E
« Reply #19 on: October 05, 2023, 07:35:52 PM »
That bottle is for when you are done with the polishing  8)
1983 Honda CB 1100F
Offline newday777
« Reply #20 on: October 05, 2023, 08:30:56 PM »
And engine covers too. My K5 was done years ago as well as my original K6 when I bought it new in 76.
Stu
My current rides
Prior bikes....
