Author Topic: 1976 Honda cb750K  (Read 42935 times)
Re: 1976 Honda cb750K
« Reply #100 on: December 01, 2023, 08:04:53 PM »
Not sure where you got that engine number John. This one is 2452000 which puts it near the end of the Canada run. Last one shows as 2465992.
Not sure where I got that! Hope to see it soon. J.
« Reply #101 on: December 02, 2023, 07:35:25 AM »
One piece at a time…… This time of year I like to bring small bits up to the house where it’s warmer. My cleaning tank is getting a bit “greasy” so small bits sneak into the dishwasher for a final rinse. I find brush paint is best for side and centre stands.
« Last Edit: December 02, 2023, 07:39:03 AM by BenelliSEI »
« Reply #102 on: December 02, 2023, 10:06:54 AM »
For your CB750K8 ?
Did the sidestand change at all after 1976 ?
« Last Edit: December 02, 2023, 11:25:36 AM by grcamna2 »
« Reply #103 on: December 02, 2023, 10:30:39 AM »
For your CB750K8 ?
Look again at the topic
« Reply #104 on: December 02, 2023, 12:01:19 PM »
For your CB750K8 ?
No. This one is off the K6. I keep the shop around 50F which is just fine when I’m wearing my insulated coveralls. Painting is tough though! I keep the paints in the house basement and bring the bits up to paint there (after they warm up!).
« Last Edit: December 02, 2023, 12:47:45 PM by BenelliSEI »
« Reply #105 on: December 02, 2023, 12:14:48 PM »
John maybe you should build a small paint box with heat??
« Reply #106 on: December 02, 2023, 12:48:39 PM »
Stu…… Corner of the basement, right next to the furnace is perfect!
« Last Edit: December 02, 2023, 04:53:44 PM by BenelliSEI »
« Reply #107 on: December 02, 2023, 04:51:33 PM »
Ooops! See the two small cans of paint on the end of the bench (photo above). I opened flat black by mistake. New motto: “Read twice, paint once”.
« Reply #108 on: December 02, 2023, 04:57:47 PM »
Did you brush on the paint?
« Reply #109 on: December 02, 2023, 05:01:01 PM »
Yes….. I always do for the centre and side stand. Lasts much longer. This one will be even better……. two coats!
« Last Edit: December 02, 2023, 05:04:59 PM by BenelliSEI »
« Reply #110 on: December 02, 2023, 05:09:55 PM »
One flat and 1 semigloss....
« Reply #111 on: December 02, 2023, 05:53:27 PM »
For your CB750K8 ?
One of my 'tricks' for the smaller pieces (up to about swingarm size or engine cases size) in the winter is to heat them up with my radiant heater for about an hour first. Then I paint them and let them cure in front of it, too. I keep the paint in the house in cold weather, too. This has worked well even when it's snowing! :)
« Reply #112 on: December 03, 2023, 06:16:28 AM »
When I pulled the centre stand, the split pin in the end of the pivot tube was not there. That is the third place on this bike I’ve discovered missing fasteners. I realize this one is just a “safety”, but it bugs me. When the front wheel comes off for respoking I’ll be checking that end very carefully!
« Reply #113 on: December 03, 2023, 11:37:26 AM »
Back end is done. NOS seat looks good. The Bridgestone Accolade tires are a first for me, but they look OK too.
Next will be fresh spokes up front and whatever else I find. Fork oil and brake fluid at least. I rebuilt the master and brake caliper when I first picked it up.
Tomorrow is “bench clean up”. I have four 24” X 8’ benches running down the north wall of my shop and today I had trouble finding a work space!
« Last Edit: December 03, 2023, 06:03:21 PM by BenelliSEI »
« Reply #114 on: December 04, 2023, 01:12:30 PM »
Turned the bike around and got the front wheel off and apart. Next is to pull off the tire and respoked the front rim. I had to “knock back” the caliper. I bet the small hole in the master is plugged. The master and caliper were rebuilt (by me) 5 years ago. Will get to it after the wheel.
Once again, I forgot to remove the speedo cable before dropping the wheel!!! Fortunately there was enough junk lying around to prop it up temporarily.
One day I will come across one of those neat scissor jacks but in the meantime two jack stands and a piece of wood does the job. Frame, rims and chrome on this bike is in perfect shape. Obviously has never spent anytime outside. It came with a single stay 1977-78 front fender which I used on my ‘75 cb750F. Not sure where I got the front fender. It looks very new. Moving ahead.
« Last Edit: December 04, 2023, 05:39:03 PM by BenelliSEI »
Online denward17
« Reply #115 on: December 04, 2023, 02:24:25 PM »
^That back end looks good..........Is this your bike or doing one for a friend?
« Reply #116 on: December 04, 2023, 03:54:12 PM »
Welcome home Den! Check out the first post on page 1. It’s mine, “by accident”! I’m trying to downsize, but it’s so nice I just might keep it.
« Last Edit: December 04, 2023, 05:25:01 PM by BenelliSEI »
Offline Mark1976
« Reply #117 on: December 04, 2023, 06:30:53 PM »
Glad to know I'm not the only one who's proped up my bike in this manner, and I have the same exact stands, circa 1976...
Start with the end in mind...
« Reply #118 on: December 04, 2023, 06:41:38 PM »
That’s exactly right. In the late ‘70’s I was racing a 1293 cc Mini Cooper S. We had 5 of them in a shop we rented. When we moved out, I took home about  a dozen of those stands! Still have a few milk crates full of them! I think they sold for about $3.99 each?
Offline Mark1976
« Reply #119 on: December 04, 2023, 07:32:22 PM »
Lol, I think you're right, $3.99, when a dollar was.... well a dollar.
« Reply #120 on: December 05, 2023, 07:16:22 AM »
I also have some stands like that, tried and true
Offline Magpie
« Reply #121 on: December 05, 2023, 08:39:02 AM »
You're setting the bar very high here John! Good/nice work. Cliff.
« Reply #122 on: December 05, 2023, 09:24:15 AM »
Thanks Cliff…… it’s a nice project. Like yours, in very nice original condition to start with.
« Last Edit: December 06, 2023, 05:22:05 AM by BenelliSEI »
Offline Honda Tom
  • 1970 CB750
« Reply #123 on: December 06, 2023, 04:24:12 PM »
Nice Job!!!
I just started a restoration on a 1970, K0.
How did you get the cylinder studs out.
And did you remove the Kickstarter gear?
I can't get the roll pin out, and I don't want to damage the case.
Thanks for the tips.
Tom
« Reply #124 on: December 06, 2023, 04:33:47 PM »
Nice Job!!!
Tom
Tom…. Heat the studs a few times and let them cool. I have a Craftsman Stud Remover. It’s a horrible “knuckle” thing that you attach to a very long, 1/2” drive breaker bar. As you pull, it cams down onto the shaft of the stud. I sharpen the teeth inside the thing and it is brutally effective. The studs can’t be reused. Next time I’m in the shop I’ll take a picture.
Check out one of “Terry in Australia” latest posts. He has an electric device that gets them red hot so he can bend them to 90 degrees and then lever them out!
That roll pin needs to rotate before you pull it. Vice grips and soak it in penantrant. Warm the area around it. Start a separate post with that photo and ask the questions. You will get lots of great answers!
Here’s a photo of my last K0.
« Last Edit: December 06, 2023, 04:49:11 PM by BenelliSEI »
