Author Topic: Another project-1976 Honda CB550K  (Read 57083 times)
Offline Mark1976
Re: Another project-1976 Honda CB550K
« Reply #150 on: January 22, 2024, 11:48:59 AM »
   I agree, there's enough to cinch it down, you have the pinch bolt on the back as well. But there's a torque value for the top nut that's like 58lbs and it looks a little a short to sustain that. I know, seems like a lot of ft lbs for that. Dbl check,  I could be wrong...
Start with the end in mind...
« Reply #151 on: January 22, 2024, 11:50:59 AM »
Can you find a way to get a thinner top washer ?
Offline denward17
« Reply #152 on: January 22, 2024, 12:06:36 PM »
I will look for a thinner washer.....
Torque according to Honda service manual is (Steering Stem Nut) = 57.9 - 86.7 Ft lbs.
Offline Floshenbarnical
  • Money pit enjoyer
« Reply #153 on: January 22, 2024, 12:49:16 PM »
Jesus
'77 CB750 SS
« Reply #154 on: January 22, 2024, 01:33:54 PM »
I wonder if that’s the cap nut or the one under the tree top? That seems a lot!
Offline denward17
« Reply #155 on: January 22, 2024, 01:48:41 PM »
It does seem like a lot.
I think the pinch bolt under the tree is 13-18 Ft Lbs.
I did find a washer at McMaster Carr....18-8 Stainless Steel Wide-Rim Ring Shim 0.048" Thick x 1" ID x 1-1/2" OD
« Reply #156 on: January 22, 2024, 02:07:10 PM »
That seems ridiculously high. Be interested to see what anyone else suggests. I leave the chrome washer and just pull it to 25 ft.lbs. Once the pinch bolt is tight, nothing is going anywhere……
Offline Mark1976
« Reply #157 on: January 22, 2024, 02:20:51 PM »
   I don't ever remember torquing to that value, but I do know that if you don't get the upper triple tree down flush and snug on the upper race bearing adjuster nut it'll, creep loose (vibration,  road shock) and create a bit of slop in the upper race.
« Reply #158 on: January 22, 2024, 03:22:33 PM »
That will help allow you to catch more threads  ;)
« Reply #159 on: January 22, 2024, 03:23:23 PM »
Yes, this.
Offline Little_Phil
« Reply #160 on: January 23, 2024, 03:19:31 AM »
Steering stem nut is the cap nut on the top.
« Reply #161 on: January 23, 2024, 05:16:18 AM »
Make sure you have enough room in the cap nut, too many threads and the cap nut will bottom out.  The metal blade that extends from the measuring calipers is often used to get ball park ideas of depth of something you are measuring.
I'm going to have to check out Parts more pricing in that part as I had one or two rubber boots tear on me getting them out of my 550 project which is gathering parts...
Offline denward17
« Reply #162 on: January 23, 2024, 06:09:58 AM »
I did, put the nut on without a washer and it went all the way down.
As far as a torque value, I don't have the correct socket to torque down anyway, so will tighten it up real good with an adjustable wrench, when the time comes.  Waiting for that pilot lamp wiring harness to arrive and need to fix a couple of connectors in the headlight light bucket wiring before I start buttoning things up.
Offline denward17
« Reply #163 on: January 23, 2024, 11:53:52 AM »
Fixed several wiring connections today with new connectors from vintageconnections...
Picture below is supposed to be a double pole, but appeared to be broken off in a previous life and the left front turn signal connector was soldered to the back side.
Assembled the front brake caliper with new piston/o-ring seal and new pads, ready to install.
Doing some touchup paint work on the frame near the front.
« Reply #164 on: January 23, 2024, 06:10:53 PM »
Did you try a phenolic brake piston or std.?
Offline denward17
« Reply #165 on: January 23, 2024, 06:23:35 PM »
Standard from PartsNmore.
Offline denward17
« Reply #166 on: January 25, 2024, 01:23:03 PM »
Received my pilot lamp wiring harness today so I started putting the wiring back in the bucket, making all the connections and put the forks on loosely until I can get the tire on.
Those fork ears look a lot better than what I had, Thanks again Mark1976.
Also received today a clutch lever that actually fits, Thanks John.
« Reply #167 on: January 25, 2024, 01:42:35 PM »
It's fun when you start getting close!
« Reply #168 on: January 25, 2024, 01:57:05 PM »
Looking good! Glad it arrived. J.
Offline Mark1976
« Reply #169 on: January 25, 2024, 03:34:37 PM »
   Just happy to have helped out, everything looks great!
Offline denward17
« Reply #170 on: January 26, 2024, 01:36:43 PM »
A little more progress today, front fender, wheel and brake caliper on.
All bolts on top bridge torqued, lower bridge not torqued yet, waiting to get front brake operational so I can jounce the front forks a few times before tightening the rest of the bolts.
Brake hoses and bleeding the caliper next on the agenda.
« Reply #171 on: January 26, 2024, 03:05:06 PM »
Dennis…. Looking really great! Moving ahead fast too. You can just roll the bike up against the wall to do the “bounce”!
Offline denward17
« Reply #172 on: January 26, 2024, 03:14:16 PM »
Well, that's a good idea!
Offline Mark1976
« Reply #173 on: January 26, 2024, 03:59:17 PM »
   One thing at a time, looking really great!
« Reply #174 on: January 26, 2024, 05:32:19 PM »
Good to see the OEM Honda master on it  8)
