Author Topic: Idle Screw not touching, '73 CB350F  (Read 573 times)
Offline Lou
« on: December 10, 2023, 02:58:14 PM »
Hi all,
I'm putting my carbs back on after a rebuild and noticed that the idle screw does not touch the part of the arm that adjusts the idle (see the side view pic of the screw). I noticed that the bolts on the top of the accelerator assembly are not lined up (see the top view pic). I tried loosening bolt #2 to line it up with #1 but it isn't moving. I *think* if I can line it up with bolt #1, the arm will move in the right direction and the idle screw will touch.
Any suggestions on how to move it? Also, will moving it also move my slides and I will need to do the bench synch again?
Thanks in advance.
Re: Idle Screw not touching, '73 CB350F
« Reply #1 on: December 10, 2023, 03:39:29 PM »
You have not bench synced properly
« Reply #2 on: December 10, 2023, 05:20:16 PM »
Those misaligned screws: one of them is not on the flat spot of the throttle's shaft. They should both have little flat spots where they locate to hold the collar in place.
