Author Topic: 1975 400/4 Crankshaft Bearings  (Read 649 times)
Offline MDW
  • 1975 Honda 400 Four Super Sport
« on: January 15, 2024, 09:53:12 AM »
Question about main journal bearing choice. Is it a problem to use different color bearings across the 5 journals? As best I can measure it I need a mix of green and brown (the only colors I can find). I am going to plastiguage them to check they are all in spec.
Thanks
Re: 1975 400/4 Crankshaft Bearings
« Reply #1 on: January 15, 2024, 10:00:22 AM »
Not a problem, just use what you need.
Get a good machinist to accurately measure the main bearing pin sizes and use those
Offline MDW
« Reply #2 on: January 15, 2024, 10:18:49 AM »
Thanks!
Offline Mark1976
« Reply #3 on: January 15, 2024, 08:02:19 PM »
   That's exactly what happens, the last two bottom ends I replaced mains in had 3 greens and 2 browns. Do a double check with plastigauge once they're installed and confirm your clearance's. Then you're good to go..
Start with the end in mind...
Offline MDW
« Reply #4 on: January 28, 2024, 02:23:47 PM »
Thanks. I also ended up with 3 green and 2 brown. I plastigauged them and with all came out at 0.038, which should mean it's good to go.
Offline Tracksnblades1
« Reply #5 on: January 28, 2024, 02:39:15 PM »
+1
Age Quod Agis
