Author Topic: 1972 Honda cb 350 four jack shaft install into starter clutch  (Read 624 times)
Offline pablo63
« on: February 08, 2024, 04:23:10 PM »
I did a practice run for case assembly & had some difficulty getting the shaft to go through the starter clutch but after 15 min of fiddling it lined up .I then seperated the cases and applied hondabond & torqed to specs
Now after hrs of trying I just cant get the shaft into the starter clutch as it seems to be unable to line up properly .Just wandering if someone has had this problem  .& where did I go wrong .
  Thx
Offline Flyin900
Re: 1972 Honda cb 350 four jack shaft install into starter clutch
« Reply #1 on: February 09, 2024, 01:25:43 PM »
What’s a jack shaft? Some pictures would help visually see what issue your dealing with there.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Online bryanj
« Reply #2 on: February 10, 2024, 12:01:04 AM »
Primary drive shaft, problem is probably a tiny "kink" in the primary chain you can try slighlty rotating crank back and forth to see if start clutch/primary gear move to to the rear a fraction.
Occasionaly you get one the is awkward and usualy responds to the mechanic going away for tea/coffee!
Online rotortiller
« Reply #3 on: February 10, 2024, 04:44:22 AM »
It's a close cousin to the "Johnson Rod". lol
« Reply #4 on: February 10, 2024, 08:04:01 AM »
Works almost every time with very large double reduction planetary covers too…more troublesome ones you may just have to go home and try again in the morning…
« Reply #5 on: February 10, 2024, 10:17:09 AM »
If you're talking about the Starter Reduction Gear on the 750...
you must install the gear into the pocket first, then rotate it to the left a little until the hole in the gear aligns with the hole in the case. Then set the shaft in, put the flat washer on the top, then install the cover.
