Author Topic: Early forks question  (Read 980 times)
Offline Swoop
« on: March 19, 2024, 05:05:52 AM »
What are you guys using (other than specific purposed tool) to drive in the fork seals on 69-71 forks?
I forgot what I’ve used in the past, thought 1 1/4 abs pipe might work but just a tad small.
Thanks
Steve
Offline 69cb750
Re: Early forks question
« Reply #1 on: March 19, 2024, 05:10:48 AM »
Large socket that fits seal
Offline Swoop
« Reply #2 on: March 19, 2024, 05:26:08 AM »
Thanks but I think the fork tube has to go in first….no?
« Reply #3 on: March 19, 2024, 05:33:49 AM »
Thanks
Steve
Split the 1 1/4" in half and hold together with rubber bands.
Offline Scootch
  • Someday I'll know what I needed to know years ago
« Reply #4 on: March 19, 2024, 05:52:03 AM »
PVC pipe of the appropriate size
Offline Swoop
« Reply #5 on: March 19, 2024, 05:52:31 AM »
Thanks….also thought of making 1 cut lengthwise, lube it up and see if I can slide it down.
Offline Swoop
« Reply #6 on: March 19, 2024, 06:05:25 AM »
PVC pipe seems to have similar dimensions to abs
Online BenelliSEI
« Reply #7 on: March 19, 2024, 08:25:47 PM »
I like that idea, will try it too.
« Reply #8 on: March 19, 2024, 09:47:31 PM »
Set of exhaust pipe clamps, flange-side up, held together gently with 2 hose clamps. Then I tap it down with a plastic hammer, gently.
Rube Goldberg enough for ya? 'Tis for me. :D
This bike is sorta like the M1911A(n)....use the rim of the bullet's case head to remove the screws that hold the grip scales on,  then you can effect the 100% teardown (or reassembly) of it w/o outside tools...
Offline Prospect
« Reply #9 on: March 20, 2024, 02:08:39 AM »
I use a reducing size abs. I can't remember the size and I'm away from home. Works well and the larger side gives you more area to hit on.
https://www.homehardware.ca/en/1-14-hub-x-1-12-hub-abs-increaser/p/3253222
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
« Reply #10 on: March 20, 2024, 04:57:33 AM »
Mark,
Maybe it's a nationality thing, but this makes no sense to me whatever! Can you explain?
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
Offline Bodi
« Reply #11 on: March 20, 2024, 09:23:35 AM »
Field stripping a .45 cal automatic pistol. The M1911 was a military gun now made by several manufacturers and pretty popular with gun crazy US citizens.
« Reply #12 on: March 20, 2024, 06:36:01 PM »
You don't remove the grips when "field stripping" a firearm. And most quality 1911s these days have either Torx or Socket head screws in the grips.
In the military manual (circa 1917) I have it shows stripping the pistol all the way to the grips, and since they are rosewood, using them to make an emergency fire. ;)
That's where the mention of using the spent case as a screwdriver came in.
