Author Topic: Lose your starter button spring?  (Read 6897 times)
Offline Jonesy
  • Shop Rat
« on: March 17, 2007, 02:29:16 PM »
Don't panic. Grab that Bic clickable pen in your pocket and remove the ink tube inside. Take the small spring off it and snip off about 4-5mm of it. The pen probably won't work anymore, but at least your starter button will.
Offline CBGBs
    • Ride or Rot vintage motorcycle event in FTW
Re: Lose your starter button spring?
« Reply #1 on: March 18, 2007, 06:53:28 PM »
Yes, this works like a charm. I did this last weekend. Thought I was pretty crafty. I see I wasn't the only one. 8)
Its a tough job getting the spring seated. I made a little split fork out of thin aluminum sheet with a dremel, to hold back the spring and allow for the buttons pin to slide through the fork. That also worked very well.
'66 CB77 Superhawk  '73 CB350G Cafe  '75 CB400F '65 S90  '78 CB750 SS
Offline mrbreeze
  • Not your average
« Reply #2 on: March 18, 2007, 08:14:42 PM »
This message brought to you by the Mcguyver Institute....Motorcycle division.
MEMBER # 257
Offline CrisPDuk
  • Christ on a bike! Me, an
« Reply #3 on: March 20, 2007, 12:04:06 AM »
That's all well and good Jonesy, but what if you've still got the spring, but can't find the button :( ::)
1978 CB550 K3
1985 H100S
Offline Jonesy
  • Shop Rat
« Reply #4 on: March 20, 2007, 04:40:00 AM »
"Dammit Jim, I'm a doctor- not a miracle worker!!"  ;D :D
Not sure what to tell you on that one. I'll have to figure out a quick one for that...
Offline CrisPDuk
« Reply #5 on: March 20, 2007, 05:29:31 AM »
I know Dammit Dan, but who is Dammit Jim ???
Don't worry too much about it Jonesy ;) I'm putting some later CB controls on her anyway, until then I'll have to do the same as I do with the wife in morning ::) and kick some life into her ;D
1978 CB550 K3
1985 H100S
Offline CrisPDuk
« Reply #6 on: March 20, 2007, 05:30:56 AM »
And if MrsD reads the above, this could well be the last you ever hear from me :o
1978 CB550 K3
1985 H100S
Offline Jonesy
  • Shop Rat
« Reply #7 on: March 20, 2007, 05:36:11 AM »
"Dammit Jim" was from Dr. McCoy in Star Trek. Some of his most popular sayings began with "Dammit, Jim I'm a Doctor, not a (fill in the blank)".
Offline crazypj
  • I'm brill, me
« Reply #8 on: March 20, 2007, 11:23:15 PM »
I think Mikes XS (the Yamaha guy) has stock and solid metal replacement button for Ymah, look same as Honda ones to me
 Personally, I'd make a shiny stainless steel one ;D
PJ
Offline Jonesy
  • Shop Rat
« Reply #9 on: March 21, 2007, 05:54:29 AM »
Out of curiousity I purchased one of those replica ones from PartsN'More. They are a spot-on match. (Have yet to install it and see how it works, but it can easily be modded to fit.)
Offline luckysox
« Reply #10 on: March 27, 2007, 03:59:58 PM »
Buy a new one from Honda!  The button and spring are still available   35317-001-310 Button      35318-259-000 Spring
Offline Gordon
  • 750K1, 550K2
« Reply #11 on: March 27, 2007, 04:56:32 PM »
This is the "Tricks and Tips" section, not the "Buy it from the Dealer" section. ;) ;D
« Reply #12 on: March 27, 2007, 05:10:21 PM »
You can also use a pen spring if you lose one of the mixture screw springs.
Offline Jonesy
  • Shop Rat
« Reply #13 on: March 28, 2007, 05:22:21 AM »
I looked at those, but they are only for the early controls. Has anyone tried the said switch in a later model bike?
