Author Topic: '76 CB550-inside look at tappet noise  (Read 2133 times)
Offline denward17
« on: May 09, 2024, 07:28:28 AM »
Hey Guys, Trying to isolate a noisy CB550 top end.
Going through some steps and took the valve adjuster covers off to check valve clearance.
Top of all valve springs/retainers are wet with oil, so assume oil is getting to top end as it should.
Looking inside the adjuster covers on 2 exhaust and 1 intake I see what looks like witness marks where the rocker arm adjuster nut might be hitting inside the cover.
What do you guys think?  Have you seen this before?
Assume the valve cover rocker shafts are worn?  Or could the valve clearance be out enough to hit?
Re: '76 CB550-inside look at tappet noise
« Reply #1 on: May 09, 2024, 07:56:23 AM »
That does not look right, what could be causing that?
Offline willbird
« Reply #2 on: May 09, 2024, 08:23:43 AM »
I wondered if a PO had a nut come loose and move around in there ?
« Reply #3 on: May 09, 2024, 08:41:47 AM »
If not, he should see a witness mark also on the culprit that offended his cover..
Offline denward17
« Reply #4 on: May 09, 2024, 08:47:16 AM »
Just checked clearances, ad am surprised by what I see.  I initially set all to spec (I=.002" E=.003")
Settings now:
      1             2             3            4
I  >.008       .005       .004        .005
E    .003       .003       .004        .004
Exhaust clearances are consistent, but Intakes grew quite a bit, especially #1 (greater than .008, didn't have anything to measure that would fit).
I haven't checked the nuts yet to see if all are tight, but they are all on at least.
On the exhaust #1 and 2, I can wiggle the rocker arm side to side quite a bit.
How could the intake clearances back off that much just with 30 miles on it?
Offline willbird
« Reply #5 on: May 09, 2024, 08:53:23 AM »
Settings now:
      1             2             3            4
I know you know but still need to ask, is/was the engine stone cold, as in has not run in 12 hours cold ??
Bill
Offline denward17
« Reply #6 on: May 09, 2024, 08:56:07 AM »
^Yes cold, ran it yesterday for about 3 minutes.
All adjuster nuts were tight.
« Last Edit: May 09, 2024, 09:44:02 AM by denward17 »
Offline denward17
« Reply #7 on: May 09, 2024, 10:46:20 AM »
Pretty sure I found the problem.
Took off the end caps and the outside rocker shaft (#1-2 Intake) will visibly rock up and down.
Looks like I need to locate another valve cover with the pinned shafts ('77 and '78 models only I assume).
Will the K and F models work the same?
Online bryanj
« Reply #8 on: May 09, 2024, 11:15:40 AM »
Rocker shafts have worn the cam cover holes oval, you need another cover preferably 77/78 where the shafts were pinned
Offline flatlander
« Reply #9 on: May 09, 2024, 11:38:50 AM »
yes they're the same.
Online bryanj
« Reply #10 on: May 09, 2024, 12:58:03 PM »
There are nobushings, the shafts fit direct into cover, could be bored out and bushes fitted but probably cost a lot more than a used cover
Offline denward17
« Reply #12 on: May 09, 2024, 02:08:43 PM »
I purchased this one, hope it works.
https://www.ebay.com/itm/404748483644
Offline denward17
« Reply #13 on: May 09, 2024, 04:49:13 PM »
You need to make sure and reuse your rockers with your cam and valve tops. There’s a wear pattern that you want to observe.
Understood....
How do the pins come out of the "pinned" rocker shafts, from the top down?
« Reply #14 on: May 09, 2024, 05:47:56 PM »
Following
Offline craz1
  • CDA, Idaho
« Reply #15 on: May 09, 2024, 09:49:49 PM »
You will need the shafts and pins. Doesn't look like you get the shafts or pins with those covers. When I rebuilt my CB550 I located new shafts form Europe, which are hard to find new. I also sent my cam and rockers to common motor and had them reworked. Cost a bit but well worth it in my opinion. Smoothest running bike I have owned. (Which has been sold)
I do have some used shafts and pins which are on ebay at the moment. Shafts have some wear but usable. If you need them let me know.
That wear is common for the early CB550 so you best bet is the 77-78 cover.
74 CB550,73 Z1900, 74 Z1900, 75 Z1900,
72 XS2650, 73 RD350, 2013 FJR1300, 84 XJ550 YAM
« Reply #16 on: May 09, 2024, 10:09:06 PM »
I purchased an exhaust system from them;good folks from the Ukraine.
I rode over and picked it up from where I live and it saved me on shipping.
What's the visual difference(the type of hold-down pins for the rocker shafts)between rocker shafts hold-down pins on the one you just purchased(1975)here,or the 1977/78 rocker shafts pins ??
There are threads here on the forum with much more information on solving this issue,even on an older model cam cover.
« Last Edit: May 10, 2024, 12:32:08 AM by grcamna2 »
Online bryanj
« Reply #17 on: May 09, 2024, 11:38:33 PM »
From the pics they posted you will not need to change the rocker arms, especially as your have been running on wandering shafts and will be worn "wrongly"
Post some close up pictures of the pads on the cam followers when it arrives and i will comment better them as they are hard plated.
They one you bought was a far better deal as it came with all the internals and the expensive tacho drive casting.
READ THE MANUAL CAREFULLY about refitting the cover or you will bend valves and break guides
« Last Edit: May 09, 2024, 11:41:09 PM by bryanj »
Offline flatlander
« Reply #18 on: May 09, 2024, 11:49:19 PM »
yes they're in there. pins are under the 4 nuts you see on the photos in the middle of the cover and without shafts, the rockers would stay as neatly in place.
Offline flatlander
« Reply #19 on: May 09, 2024, 11:50:43 PM »
yes, tap them out. careful not to damage the threads (keep nut on).
« Reply #20 on: May 10, 2024, 12:05:22 AM »
Dang that is a high price for the late cover, but you are pulling trigger quickly rather than waiting for a deal...
But, cannot blame you for that. It is years after I picked up my cover, so that is to be considered...
Everything is so stinking high these days and low fixed incomes suck
Online bryanj
« Reply #21 on: May 10, 2024, 12:46:13 AM »
Those pins rarely "tap" out, they frequently get badly damaged removing them, like i said i would fit the cover complete as the Hondas are not like old cars
Offline Little_Phil
« Reply #22 on: May 10, 2024, 04:00:16 AM »
The item you bought still has a listing as they presumably have another. Their listing says taken from bike at 95905 miles!
Make sure that the one they send you has the pinned shafts and tacho drive, as my June 75 550F doesn't have the pinned shafts so I suppose they came in at the end of the year.
You can sell the tacho drive as they make $$.
Offline denward17
« Reply #23 on: May 10, 2024, 04:48:32 AM »
I was assuming I could use my current tacho drive from the bad cover?
Online bryanj
« Reply #24 on: May 10, 2024, 05:59:03 AM »
You can, but it is a part that breake easily so if the one on the new cover is good i would leave it alone.
A new pattern casting alone is over $100, the gear and washer have been nla for a long time so i would expect a used complete unit to sell for at least $70
