Author Topic: Lowering  (Read 1167 times)
Offline Slow2
  • 1971 CB750, 1974 Cb750, 2004 Yamaha Roadstar chopp
Lowering
« on: May 11, 2024, 12:47:14 PM »
If I lower my k5 with shorter shocks and slide the front tubes up, will I need to remove the center stand? Thanks!!
Ed
Re: Lowering
« Reply #1 on: May 11, 2024, 01:34:08 PM »
Only if you want to go round LH corners
Re: Lowering
« Reply #2 on: May 11, 2024, 03:04:45 PM »
How far do you want to drop it?
Re: Lowering
« Reply #3 on: May 11, 2024, 06:55:04 PM »
I did that with the 750 on the cover of my book. While I wouldn't go racing with it unless I did something about moving the centerstand's step arm, but the bike has been running around here (Denver area) ever since, works fine.
Re: Lowering
« Reply #4 on: May 11, 2024, 11:28:26 PM »
If it's because your legs are on the shorter side, consider a lower seat...super popular mod in Japan so japanese parts suppliers such as Yamiya, etc ofter reproductions with less and/or thinner foam
Offline Slow2
Re: Lowering
« Reply #5 on: May 12, 2024, 03:57:51 PM »
Thanks everyone for the replies. I’m going to leave it on for now. I’m not lowering it excessively. My days of knee dragging are long past. I’m content with a few miles without my back killing me, lol. Thanks again, everyone.
Ed
Offline M 750K6
Re: Lowering
« Reply #6 on: May 13, 2024, 03:58:35 AM »
Lowering is possibly worse for a bad back, as it reduces suspension travel.
Re: Lowering
« Reply #7 on: May 13, 2024, 10:34:20 PM »
Ed
The old school way to lower them without sacrificing much suspension travel was with shock lowering blocks and handle bar set backs. Which allowed the front forks to be slid up to maintain the factory fork rake angle. The lowering blocks angled the factory shocks back near the rear axle bolt which usually required setting the shocks for a heavier load. Made them ride good. The shock had to move farther for the same amount of swing arm movement.
If I still can’t attach a picture google “Honda cb750 rear shock lowering blocks” click “images” the Carpy’s picture shows the same that were available years ago.. Lookslike they’re still available for $20.00 or less..
I run my F1 forks up almost touching the handle bars. I like the minor steeper rake angle. I think it steers lighter, quicker and is more energetic in the corners. It doesn’t seem to caster (think chopper flop) as bad in slow slow maneuvering either..
Edit:  well it still won’t let me post pictures tonight “file too big”..
Anyway follow this sohc link
 http://forums.sohc4.net/index.php/topic,178485.msg2071596.html#msg2071596
Scroll down to gold bike and zoom in on rear wheel..
« Last Edit: May 13, 2024, 10:49:50 PM by Tracksnblades1 »
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
Re: Lowering
« Reply #8 on: May 17, 2024, 06:44:59 AM »
Its easy enough to convert to eye to eye and have better options than the spongy short shocks
Offline Floshenbarnical
  • Money pit enjoyer
Re: Lowering
« Reply #9 on: May 17, 2024, 07:04:34 AM »
Please tell me more about this
'77 CB750 SS
  • Gusto mo titi ko?
    • project
Re: Lowering
« Reply #10 on: May 17, 2024, 11:25:29 AM »
Try here -> http://www.lowridersbysummers.com/twt/17/index.html
Re: Lowering
« Reply #11 on: May 18, 2024, 07:57:32 AM »
I have a -20mm Yamiya seat on my K3 750, nice seat. looks great and is soft enough.
