Author Topic: Maxi Dwell  (Read 858 times)
Offline Swoop
Maxi Dwell
« on: May 28, 2024, 07:54:02 AM »
Does anyone have the literature for setting up the Maxi dwell points on a 750?
Offline 69cb750
Re: Maxi Dwell
« Reply #1 on: May 28, 2024, 06:48:18 PM »
Maxi dwell ?
Adjust the points so they never open then you have 360 degree dwell, thats maxi dwell all right.
If you set the points to .014" you can check when the points close and when they open, that is the dwell.
Re: Maxi Dwell
« Reply #2 on: May 28, 2024, 07:14:54 PM »
Maxi dwell ?
That's funny. I run points in my Hayabusa. ::) ::)
Offline Swoop
Re: Maxi Dwell
« Reply #3 on: May 29, 2024, 04:27:00 AM »
Maxi dwell ?
Thanks my friend, I’ll give it a try.
Re: Maxi Dwell
« Reply #4 on: May 29, 2024, 07:29:14 AM »
Frank had one.  And Mike posted  "Forget that crap. Step into the 90's and get a Dyna 2000"....back in 2007!!
http://forums.sohc4.net/index.php?topic=27532.0
Re: Maxi Dwell
« Reply #5 on: May 29, 2024, 07:35:16 AM »
I'm still points, I use feeler gauges, tried a dwell meter, got a variety of results, went back to feeler gauge
I'm old
Offline Swoop
Re: Maxi Dwell
« Reply #6 on: May 29, 2024, 11:33:35 AM »
I'm old
Ditto….you can always carry a spare set of points on a trip and fix it on the side of the road. Try that with electronic ign.
If I wanted to ride a something antiseptic….I’d ride a Busa
Re: Maxi Dwell
« Reply #7 on: May 29, 2024, 11:56:48 AM »
That's why back then I have decided for the best of both worlds and to make my own transistor ignition module with the breakerpoints still switchng the control current. In the nineties I had plans to go as far as Turkye and maybe even further. Although I never went there, my ignition has proved ultra reliable.
Offline Swoop
Re: Maxi Dwell
« Reply #8 on: May 29, 2024, 02:43:38 PM »
Guess I’ll have to figure it out myself  :(
Re: Maxi Dwell
« Reply #9 on: May 30, 2024, 12:27:57 AM »
I dunno what benefit you expect. I mean, wasn't the maxi-dwell developed for V-8s, asphixed as they were having only one contactbreaker to do it all? In our 4 cylinder bikes, with two separate ignition sets, there's ample saturation of the coils. I don't see how a maxi-dwell could offer improvement.
« Last Edit: May 31, 2024, 01:48:01 PM by Deltarider »
