Author Topic: Deck  (Read 1118 times)
Offline dhall57
Deck
« on: July 26, 2024, 11:11:43 AM »
Has anyone had a deck built or repaired recently. My current one has seen it's better days and needs replacing. It's a 12 X 20 and my plan is to use premium treated wood decking not the composite fake boards(which is really pricey) with aluminum railing and gate. I know someone who does quality work and they are giving me quote between 9 and 10 grand materials and labor. A little more expensive than I thought but I know building materials are high and you get what you pay for and I know he wouldn't cut any corners and would do me a good job. Let me know what you think.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Re: Deck
« Reply #1 on: July 26, 2024, 11:27:30 AM »
My mom had a new deck about the same size put in recently, and I think the materials were about 2-3 thousand? My nephew and his friend did the work; I don't know how much she paid them. I'll try to remember to ask her when we talk next Sunday.
Re: Deck
« Reply #2 on: July 26, 2024, 11:32:15 AM »
That's good,considering the cost of materials.
Online jgger
Re: Deck
« Reply #3 on: July 26, 2024, 02:36:45 PM »
If that's new decking over existing joist and nailed down, then WAY too much.
Re: Deck
« Reply #4 on: July 29, 2024, 11:57:51 AM »
I "refurb'd" mine some 12 years ago by laying the vinyl-clad composite boards (of the same width) over the older redwood, which was showing wear, but still good. It looked ratty. I also replaced the redwood hand rails with these composite boards, and overlaid the steps (there's 9 steps up to it from the ground, bi-level house). Today it still looks new!
This has turned out to be the best decking decision I've ever made, and if I had to do it all over from scratch I'd use treated lumber under the composite again. It doesn't have to be re-done any time soon.
It's not the Trex brand: that type of composite only seems to last about 12-15 years. I was forewarned about that by a friend in the construction business when I did it: I used the Veranda brand.
Re: Deck
« Reply #5 on: July 29, 2024, 02:27:45 PM »
Does it get slippery ?
Re: Deck
« Reply #6 on: July 29, 2024, 05:28:19 PM »
Only when the winter sub-zero manages to put ice on it. That's only happened twice that I remember, when we had a 'snap-storm' here. Those are storms when it goes from about 50-60 degrees to 0-10 degrees in less than an hour, usually starting with rain that turns to sleet and then ice, followed by snow, about 1"-3". We get those about twice a year: if the sun was out first (and it didn't happen at night) then the deck is fine.
The Trex in the local parks gets iced over a lot more, making those walkways nasty in cold, wet weather.
Re: Deck
« Reply #7 on: July 29, 2024, 05:42:40 PM »
I asked because of the vinyl covering.
Offline jlh3rd
Re: Deck
« Reply #8 on: July 30, 2024, 04:35:24 AM »
I have the vinyl decking and it's no more slippery than wood.
Re: Deck
« Reply #9 on: July 31, 2024, 08:03:39 AM »
I've built and repaired quite a few decks over the years.  I would do some investigation on the frame, can that be reused?  If yes, then replacing just the deck boards is a possibility and fairly basic carpentry work.
Dont you have a son?  Perfect father/son project!
Offline Kelly E
  • Geriatric Hooligan
Re: Deck
« Reply #10 on: August 01, 2024, 07:14:34 AM »
My contractor recommended Timber Tech decking. He said it doesn't swell or anything bad over the years. It also has all stainless steel hidden hardware.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Re: Deck
« Reply #11 on: August 01, 2024, 07:18:59 AM »
Timber Tech is what I put on a friend's deck this spring. It's definitely better than the others.
