Author Topic: Honda CR50 Knockoff Clutch Question  (Read 779 times)
Offline Dr. Frankenstein
« on: November 10, 2024, 06:25:57 PM »
I have a little Chinese knockoff of the Honda CR50 I'm working on for my grandson, but I can't get it to shift UP from first into the upper gears without me stopping and physically pulling up the shifter; I've taken that bike apart four times, everything seems to be where it needs to be, it rolls over smoothly on the bench and seems to shift through all the gears just fine, but put it on the ground and ride it, it just does Not want to upshift. First gear is fine, and it's fun to roll around the yard on it, but it just does not want to upshift! I've taken the engine apart and rebuilt it four times, tried adjusting the clutch In and Out, replaced the clutch itself, and am at a loss as to what it could be -(unless it's because I'm 6'1" and a hefty 235 lbs and my weight is doing something to the shift dogs)...does anybody have any ideas as to what it could be?
Offline BenelliSEI
  • 1969 cb750
Re: Honda CR50 Knockoff Clutch Question
« Reply #1 on: November 11, 2024, 05:44:04 AM »
Any chance your weight is eliminating drive chain slack to the point it’s twisting/ pulling the output shaft rearwards? This could be creating lock ups in the tranny. Those things aren’t exactly built for much abuse!
« Last Edit: November 11, 2024, 05:47:38 AM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: November 11, 2024, 05:47:11 AM »
P.S.  Find a HONDA. Around here they appear to be indestructible!
« Reply #3 on: November 11, 2024, 09:44:44 AM »
"Any chance your weight is eliminating drive chain slack to the point it’s twisting/ pulling the output shaft rearwards?
This I do not know - and I have yet to experiment with that, because he doesn't know how to ride yet - and I would LOVE to find a small used Honda for him, but even those command 'big bike' prices!
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: November 11, 2024, 10:26:02 AM »
Sit on it and see how tight you pull the chain. That could be the problem…..
« Reply #5 on: November 11, 2024, 02:45:02 PM »
Huh - I will try that...
