Author Topic: Vac Sync questions  (Read 732 times)
Offline Duanob
  • Bold Timer
  • Gotcha!
Vac Sync questions
« on: January 07, 2025, 05:23:38 PM »
Memory refresher on syncing carbs, just some final tweaks to make my '76 CB550K road ready:
1 Do I need to sync the carbs if I changed the needle clip position?
2 Does the bike need to be completely warmed up for syncing?
Thanks.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Re: Vac Sync questions
« Reply #1 on: January 07, 2025, 05:56:21 PM »
Yes to both
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #2 on: January 08, 2025, 04:26:13 PM »
Thanks man! Now I just need to clear the snow off the drive.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
« Reply #3 on: January 08, 2025, 11:51:55 PM »
be sure your ignition is perfect first!
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #4 on: January 09, 2025, 06:44:30 AM »
Valves adjusted too.
I synchronize last, after all tune up steps are done.
Bike warm, fan blowing on it from the front.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #5 on: January 09, 2025, 09:15:31 AM »
Good advice!  Set ignition then clear the snow!!
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #6 on: January 09, 2025, 12:32:54 PM »
Been through everything else. Was running a bit rich so I changed needle clip position by 1 notch. Will do a carb sync and it should be ready for the road.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline denward17
« Reply #7 on: January 09, 2025, 12:52:23 PM »
Just for posterity, what position did you change to?
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #8 on: January 10, 2025, 03:51:20 PM »
Went from 4th from the top to 3rd or middle slot. It will lower the needle in the needle jet. The bike came with PODs so I'm fiddling with it to get to run the most efficient possible without the OEM intake set up. Also came with a 4 into 1 exhaust. I bought one size bigger main jets, using the OEM size pilot jets. So far it starts good, runs good. It takes a bit for the idle to settle so I think the running rich might cause that. It 's a winter project. The only problem is road testing this time of year. Got more snow today. :/
« Last Edit: January 10, 2025, 03:53:30 PM by Duanob »
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline denward17
« Reply #9 on: January 10, 2025, 07:33:58 PM »
The center position is where I ended up on my '76 550K (stock airbox/stock pipes, stock jets).  If yours is like mine, it will run perfect after it warms up, but I need to use the choke a little more because it is leaner when cold.  Also just a little harder to start cold.
