Author Topic: Anyone Rebuilt K5/K6 & F0/F1 Petcocks? I need the oring size  (Read 1105 times)
Offline newday777
« on: January 09, 2025, 09:09:09 AM »
I have 3 of these petcocks, used, I bought new Honda sock screen kits for them, but they don't include the oring behind the cam lever in the petcocks. I believe, measured from the old worn orings, they measure @ 1.97mm x 18.68mm ID. The red arrow points to the oring (that isn't numbered in the fiche). They do leak eventually.
These petcocks have the cone shaped selector and spring behind the lever. And attach to the tank threaded bung with a nut.
I know that oring was not available in the part fiche or the size listed. Someone must know the original size (and maybe the part number)
« Last Edit: January 10, 2025, 05:39:14 AM by newday777 »
Stu
My current rides
Prior bikes....
Online Stev-o
Offline newday777
Stu
My current rides
Prior bikes....
Offline newday777
Re: K5/K6 & F0/F1 petcock Orings need to find a source
« Reply #3 on: January 09, 2025, 09:36:17 AM »
But I'm hoping someone knows what the size should be from experience with the petcocks?????
Stu
My current rides
Prior bikes....
Re: Anyone Rebuilt K5/K6 & F0/F1 Petcocks? I need to find the oring size
« Reply #4 on: January 09, 2025, 11:19:10 AM »
It was never available from Honda so the only way is trial and error fitment
Offline newday777
« Reply #5 on: January 09, 2025, 11:50:51 AM »
Understand that but asking if anyone has done it......
Stu
My current rides
Prior bikes....
Offline Deltarider
  • I'm back
Re: Anyone Rebuilt K5/K6 & F0/F1 Petcocks? I need the oring size
« Reply #6 on: January 09, 2025, 12:14:29 PM »
This O-ring 16997-467-000 can be ordered separately at CMSNL.
https://www.cmsnl.com/products/o-ring118x355_16997467000/ It measures 11,8x3,55 mm.
It is the one I needed, but I didn't want to buy the complete strainer set* which includes it. As it fits to 2125 (!) Honda models, according to CMSNL, maybe this your best bet.
* https://www.cmsnl.com/honda-cb500k2-general-export_model50441/strainer-set_16952341671/
CB500K2-ED Excel black
Offline newday777
« Reply #7 on: January 09, 2025, 12:19:55 PM »
11.8x3.55 isn't even close to the measurements I gave above. Why did you throw that in here??
Stu
My current rides
Prior bikes....
Offline Deltarider
  • I'm back
« Reply #8 on: January 09, 2025, 12:21:51 PM »
On second thoughts, it probably is not. My O-ring 16997-467-000 is the upper one, between the tank and the nut in the pic.
Offline WhyNot2
  • I'm finally an
« Reply #9 on: January 10, 2025, 05:16:35 AM »
I'm in the process of rebuilding mine.
I'm digging through my o-ring stash trying to find the right ones.
Good luck with yours.
Offline newday777
« Reply #10 on: March 08, 2025, 08:00:53 AM »
I still haven't gotten a straight answer 😕
Stu
My current rides
Prior bikes....
« Reply #11 on: March 08, 2025, 01:15:46 PM »
maybe that is because no one has the answer?
Offline 69cb750
« Reply #12 on: March 08, 2025, 05:04:10 PM »
They are 2mm x 18mm x 20mm or  2mm x 19mm x 21mm
McMaster has o rings
Offline newday777
« Reply #13 on: March 08, 2025, 06:02:36 PM »
Thanks much
Stu
My current rides
Prior bikes....
