Author Topic: Good Paint stripper...  (Read 765 times)
Offline pjlogue
« on: January 17, 2025, 01:22:19 PM »
I finally found a very good paint stripper.  It is Kleanstrip Ultra aircraft paint stripper.  This stuff does work quickly like the old style aircraft paint stripper that had the Methelene Chloride.  I don't think this has the Methelene Chloride but what ever is in it works well.  I would say it is strictly to be used outdoors with heavy gloves.  It is very volitle!!!  Kleanstrip has two types of aircraft paint stripper.  One is whimpy and not worth buying but the Ultra is good.  Amazon sells it as well as Eastwood.  It isn't cheap.  ~$49 a quart and $99 for a gallon.
Thought I woulld share the info.  ;)
-P.
Online denward17
Re: Good Paint stripper...
« Reply #1 on: January 17, 2025, 02:57:42 PM »
Good to know, I think the last time I used some it didn't have "Ultra" in the title.
What did you use it on?
Offline pjlogue
« Reply #2 on: January 17, 2025, 05:00:48 PM »
I used it on a '76 750 brake caliper and an air filter housing for a '76 GL1000.  Brake caliper took a little while but the temperature outside was in the low 40's.  The air filter housing was almost instant paint removal with upper 40's temp.  Even using it outside I had to be careful about the vapors.
-P.
« Reply #3 on: January 17, 2025, 06:21:04 PM »
-P.
Thanks for the tip!
The last one I used was utterly worthless. I'll try to find some of this before Colorado outlaws it...
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #4 on: January 17, 2025, 06:35:15 PM »
+ 1  ON the Kleenstrip. It strips clearcoat from hubs and engine cases in minutes.
1976 Z50A PARAKEET YELLOW
1970 CT70  CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVIERA BLUE
1974 CB350F GLORY BLUE BLACK METALLIC
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
Offline pjlogue
« Reply #5 on: January 18, 2025, 01:33:44 AM »
This is not what I used.  The pic you posted if for the worthless type of Kleanstrip.  The one I used is the Kleanstrip Ultra.  See attached photo of the product.
-P.
« Last Edit: January 18, 2025, 05:30:53 AM by pjlogue »
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #6 on: January 18, 2025, 07:47:03 AM »
-P.
Thank you
 I found a quart  on Ebay for $37.00.
The other stuff has worked fine for me on hubs and sidecases. Likely this will work better.
Offline pjlogue
« Reply #7 on: January 18, 2025, 12:21:55 PM »
-P.
Thank you
That's a good price!  Just be careful with the vapors as they are REAL potent.  Even outside I would get a wiff and gag.  It smells like it has an ammonia component in the mix.
-P.
