Author Topic: spark  (Read 1486 times)
Offline hymodyne
spark
« on: June 16, 2005, 04:44:40 PM »
evening,
yesterday, I spliced new plug wire on to my #4 and 1 coil leads, to make a complete set that have had their original wires replaced.After the change I ran the bike for about five minutes and put it away. today, I was working on a stop for my center stand so it wouldn't interfere with the chain. when I was done, out we roll from the garage to have our little 5 minute run. It takes forever to start and when it finally does, it sounds horrible. I feel the pipes and #'s 4 and three are cold. one and two are hot. I pulled the #4 plug and it is, as expected, wet.
the plug wires at the coils are the original. they've been bent into a "u" turn on both coils.
any suggestions? time for new coils?
hym
Re: spark
« Reply #1 on: June 16, 2005, 05:13:39 PM »
Did you confirmed that the plugs don't spark across the gaps?
Did you swap plugs 1&4 to see if the problem follows the plug or remains with the wires?
Are the plugs fouled?
If you don't feel comfortable with your wire splicing and can't figure a way to correct it, seems like replacement coils are indicated,
