Author Topic: CB750K Rear Hub Question  (Read 1879 times)
Offline Clutch Cargo
« on: March 29, 2007, 06:30:08 AM »
What's the downside of removing the rubber dampers inside of the rear hub?
Mike
1976  CB750K6
1976 GL1000
1994 - ST1100
1985 - HRS21
Offline puppytrax
Re: CB750K Rear Hub Question
« Reply #1 on: March 29, 2007, 06:42:25 AM »
Besides loud clanging noises when you brake/accelerate??   ;D
It cushions the power transmission (hence the name) from the gearbox to the wheel and vice versa...hopefully, this prolongs gearbox/bearing life...
« Last Edit: March 29, 2007, 06:44:46 AM by puppytrax »
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
Offline xtalon
« Reply #2 on: March 29, 2007, 08:57:28 AM »
Mike
...and why are you wanting to do this?
--xTalon
1976 Honda CB750K
2006 Yamaha R6v
Offline rhinoracer
« Reply #3 on: March 29, 2007, 09:25:20 AM »
Is there an upside to removing them?  :o
Baja native.
« Reply #4 on: March 29, 2007, 09:45:36 AM »
OK I'm sold  - those llittle buggers are staying in there.
Thanks for the help.
Mike
1976  CB750K6
1976 GL1000
1994 - ST1100
1985 - HRS21
Offline puppytrax
« Reply #5 on: March 29, 2007, 12:27:33 PM »
I don't know why you want to take them out, but FWIW...
I mounted a 550 front wheel + brake disk + sprocket on the back of a friends' 750...with no cush drive...this was last year, before the real brake experts here convinced me that the cush drive was necessary...on my bike...   ;)
But the 750 is still out there zooming around somewhere, so it hasn't failed yet...I'm pretty sure, because the OEM 750 wheel is still in my basement, in case the 750 owner needs it...   ;D
My misgiving came from being only able to find 6100 series bearings to use with the 550 front hub and larger dia rear axle...   :(
