Author Topic: Is this cylinder head salvageable  (Read 1144 times)
Offline FrédéricVigenon
« on: February 22, 2025, 02:21:58 AM »
Dear members
I have a little question about this cylinder head. I'm doing a full rebuild on this engine and have started to clean parts.
This engine has been sitting for a long time with the previous owner and when I removed the cylinder head gasket and cleaned the head I saw this pitting in the cylinder head.
Its to deep to get rid off with skimming the head but being an aircooled engine is this a real big problem or could I get away with this pitting.
Is there anybody here who has welded one off these heads and is that a valid option?
Photo's are attached.
Thanks in advance.
Frédéric
Offline willbird
Re: Is this cylinder head salvageable
« Reply #1 on: February 22, 2025, 06:48:56 AM »
We have an expression about whether the juice is worth the squeeze :-). I'm sure the more experienced folks will weigh in but I have seen a lot of vids where people tig weld badly damaged aluminum heads and rework them.
Bill
Offline simon#42
  • liverpool
« Reply #2 on: February 22, 2025, 07:02:41 AM »
im sure it could be welded but unless the head has had a lot of expensive port work done to it you would be better off looking for a different head .
Offline CycleRanger
  • No comment about being an
« Reply #3 on: February 22, 2025, 07:25:26 AM »
Hello! Welcome!  :)
Wow, that's some pretty deep pitting. Perhaps it could be repaired but I'd probably look for a replacement first.
Offline Alan F.
« Reply #4 on: February 22, 2025, 07:28:54 AM »
Is JBWeld not an option?
Offline willbird
« Reply #5 on: February 22, 2025, 07:35:33 AM »
The operating temperature is what gave me pause, if that was a hydraulic manifold at work and an O ring sealed there we have use the correct kind of Devcon before but temperature never goes about 130F in any of our hydraulic systems.
Offline Alan F.
« Reply #6 on: February 22, 2025, 07:51:15 AM »
https://www.jbweld.com/product/j-b-weld-twin-tube
"At room temperature, J-B Weld™ sets in 4-6 hours to a dark grey color. A full cure is reached in 15-24 hours. J-B Weld™ has a tensile strength of 5020 PSI and sets to a hard bond overnight. It can withstand temperatures up to 550ºF when fully cured."
« Reply #7 on: February 22, 2025, 08:12:32 AM »
I used to work with high temperature RTV (silicone) on steam turbine case joints. I wonder if this is an option.
Offline Rookster
« Reply #8 on: February 22, 2025, 08:21:22 AM »
Its not worth the expense to rebuild the head then hope the JB Weld doesn't leak.  If it leaks then you are looking at engine out unless the frame is cut.  The CB750 is also known for head gasket leaks.  Sometimes its the pucks but alot of times its the head gasket.  I would save yourself the trouble and get a different cylinder head.
Scott
« Reply #9 on: February 22, 2025, 12:06:55 PM »
A very poor suggestion 😕
Offline Alan F.
« Reply #10 on: February 22, 2025, 12:34:50 PM »
I've been reading and watching some videos where JB-W is used on many types of engines from over-the-road diesels to drag racing big blocks to exotic cars, it's all been done.
Then I read someone recommending Marine-Tex, which is a similar but far superior product that I used to use at work decades ago.
https://www.amazon.com/Marine-Tex-RM305K-White-oz/dp/B0014419V0
Offline jlh3rd
« Reply #11 on: February 22, 2025, 01:43:11 PM »
no dog in the fight.
FWIW
I like Project Farms.....so..
Offline Flyin900
« Reply #12 on: February 22, 2025, 04:18:20 PM »
I have used Tech Steel to rebuild fins on an air cooled engine with good results. Faster set up than JB Weld, like 15 mins and full cure in 1 hr.
It is rated at 500F, so if you in that range likely other issues are happening. Yet your internal so who knows what temps your getting there.
The suggestion of head replacement is the best then you know what your dealing with from the get go.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
« Reply #13 on: February 22, 2025, 04:27:16 PM »
I’d look for another one……
Offline tool14
« Reply #14 on: February 22, 2025, 04:55:34 PM »
i would look for different head not worth time and trouble to repair.
« Reply #15 on: February 22, 2025, 07:50:19 PM »
While it looks like a K0/1/2/3 head, any of the 750 heads from a K0-K6 will drop right on. Even the head of the F0/1 engine would fit.
I might have one  around here somewhere. What year is the bike?
« Reply #16 on: February 23, 2025, 07:26:05 AM »
That's a 550 head. If you're hard up it can be used after milling .010 or .015. The fire ring area is the important part and the corrosion doesn't look bad there. Oil drainage is via cam tunnel which doesn't look bad. Oil feed areas look OK too. I'd use a different head but it will work after milling. Pouring weld in the head isn't a good idea especially in the fire ring area....it removes the temper.
« Reply #17 on: February 23, 2025, 08:48:58 AM »
As a 550 its same as 500 so there should be lots of used out there
« Reply #18 on: February 23, 2025, 11:03:54 AM »
That's a 550 head.
Aha! You're right, I have a 750 head on my bench and 750 on the brain...  :-[
« Reply #19 on: February 23, 2025, 11:56:23 AM »
I wouldn't use it.
Offline low-side
« Reply #20 on: February 23, 2025, 05:15:24 PM »
I agree with what's been said.  It could be milled and even paired with a custom thickness head gasket, but it would probably be cheaper and easier to get another head.
