Author Topic: She's home.. '76 CB550F  (Read 1971 times)
Offline newbiecb550
« on: February 28, 2025, 02:24:16 PM »
Well here we go...
Picked her up today and unfortunately she's in the shed for the time being due to the wife saying so. Rode her about 20 miles home in the cold, which would have been easy if I didn't forget my gloves! But gave me some time to get used to her. Once I threw her on the center stand, I went over it a bit more. I'm the third owner, unknown miles. Guy who sold it didn't ride much anymore. Bike runs pretty good, some flat spots but expected as he rebuilt the carbs years ago and never synced them on the bike. He's never adjusted the valves in the 5 years he's owned it and the fork seals are leaking. Tires are 20(!) years old so those will be gone. Runs rich and stinks of fuel but rather rich than lean. Odd slip on(?) muffler that will be replaced, hopefully that's an easy fix.
So the plan is to get to it a brat/cafe style eventually. I don't want to hack up the frame and while there are some non original parts like the speedo/tach (replaced by PO and reads 67k).
Up first, all the mechanics before the good looking parts.
-Adjust vales (curious how off they are)
-Cam chain tensioner adjustment
-Adjust clutch (engages at the very end, hate it)
-Replace fork seals/oil
-Install Dynatek electronic ignition
-Buy/install regulator/rectifier from Rick's
-Remove carbs and send off to Romax Cycles
-Adjust chain slack (wayyyy too loose)
-Conduct compression test
-Most likely will replace spark plugs (NGK D7EA)
-Replace brake fluid
-Buy digisync carb tool and sync
-Replace 20 year old tires!
-Replace pod filters with stock airbox
Long list! But that's just to get her up to road worthy. Then I'll start worrying about cosmetics. Attaching some photos, curious as I saw some black hoses hanging from each carb just venting to the atmosphere. Are these some sort of emissions thing where they vent back into the stock airbox? Will work on her Wednesday and hopefully have her inside eventually!
Ugh phone didn’t save some photos so only have a few.
« Last Edit: February 28, 2025, 02:30:06 PM by newbiecb550 »
Offline denward17
Re: She's home.. '76 CB550F
« Reply #1 on: February 28, 2025, 02:30:08 PM »
Welcome to the forum and good luck with restoration.
Will be following.
Offline newday777
« Reply #2 on: February 28, 2025, 02:38:39 PM »
Welcome to the forum newbiecb550
You didn't run it by the wife before buying it?? Rutroh....
What was the temperature and where are you?
Stu
My current rides
Prior bikes....
Offline Mark1976
« Reply #3 on: February 28, 2025, 02:40:45 PM »
   Great bike, you'll enjoy it. Find a decent pipe!
Start with the end in mind...
Offline newbiecb550
« Reply #4 on: February 28, 2025, 02:50:42 PM »
Bit of a disagreement at the moment, will be worked out soon! about 50 and in the northeast.
Offline Alan F.
« Reply #5 on: February 28, 2025, 03:03:45 PM »
Sounds like he's close enough to invite to Oxford, MA or Rochester, NH on May 18th
« Reply #6 on: February 28, 2025, 05:04:57 PM »
Tell her the bike will pay for itself in gas mileage saved.
...works for me...
Offline newbiecb550
« Reply #7 on: March 03, 2025, 01:24:29 PM »
Got some parts in, gotta have the right tools for the job! JIS kit, trickle charger, correct size feeler gauges for valve job, test light and Dynatek electric ignition.
Also grabbed the battery to have it on a trickle charger. Removed the pods and will donate them via Facebook. Plan on removing the carbs Wednesday to get them shipped out. Thing runs so rich I reek of gas anytime I’m working on it.
Offline newbiecb550
« Reply #8 on: March 05, 2025, 09:35:21 AM »
Got a few minutes today and removed the tank, got the carbs off and ready to be shipped. Also knocked out the cam tensioner adjustment. Tried loosening all the tappet covers but half were on so tight and my gear wrench decided to fail, garbage it went, that I didn’t want to further mess with it. Also looks like I damaged one of the throttle cable ends when removing the carbs. Didn’t realize there were two!
« Last Edit: March 05, 2025, 09:43:17 AM by newbiecb550 »
Offline denward17
« Reply #9 on: March 05, 2025, 10:37:10 AM »
Where are you sending your carbs?
Offline newbiecb550
« Reply #10 on: March 05, 2025, 10:55:35 AM »
Romax cycles. Can’t upload a photo of the broken throttle cable. Keeps taking me to start a new topic
Offline newday777
« Reply #11 on: March 05, 2025, 11:44:31 AM »
Your photos are too large for the forum requirements.
I screenshot my pictures before posting, crop the excess. That makes my pictures small enough.
I'm in southern. Like Alan posted, we go to Riceorama and Jap Bike Mike's Swapmeets in Oxford MA.
Stu
My current rides
Prior bikes....
Offline newbiecb550
« Reply #12 on: March 05, 2025, 11:49:04 AM »
Okay thanks! Here’s a photo.
Offline newday777
« Reply #13 on: March 05, 2025, 03:46:12 PM »
Can you push the end back on the cable sheath and crimp it?
Stu
My current rides
Prior bikes....
« Reply #14 on: March 06, 2025, 07:38:11 AM »
Hard to see but is the cable frayed?  May be time for a new set and yes, there are two - "pull and push".
The hoses on the float bowls direct overflowing fuel off a hot engine.
Be sure Romax does not use aftermarket carb kits, they cause tuning issues.
Offline newbiecb550
« Reply #15 on: March 06, 2025, 10:40:52 AM »
I’ll check in a few days and actually take a photo. Got it. Didn’t know there was a pull and a push!
I asked Romax and this is what they replied with.
“ So It's a mix. I generally source all of my rebuild parts independently from Japan and oem like partzilla, but not every part is always available, so for some parts, they must to be sourced aftermarket because they're the only producers of those parts. But I only install parts I've tested and used myself. I need to be able to trust the parts I'm installing.
The service also comes with a full warranty, any issues get fixed at no charge and no wait.”
Offline newday777
« Reply #16 on: March 06, 2025, 11:51:59 AM »
How far is Romax from you??
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #17 on: March 06, 2025, 11:58:53 AM »
The gasket sets(#1) and the float valves(#2) are all you should need and are available from Honda for the carbs. The slide needles and jet emulsion tubes should be fine to clean and reuse along with the other brass jets.
https://www.southsoundhonda.com/--xpartsstream#/Honda_Powersports/CB550FA_(76)_SUPER_SPORT_550_FOUR%2c_JPN%2c_VIN%23_CB550F-2000003_TO_CB550F-2010866/CARBURETOR/b3284679-ab4c-427a-8b68-959c823bd603/ca5e2e1e-6ebb-46f2-bf9e-908b03011fed/y
Did you pop off the carb float bowls and get pictures??
Stu
My current rides
Prior bikes....
« Reply #18 on: March 07, 2025, 07:04:48 AM »
That is not necessarily true, you would need to confirm the carbs have genuine Keihin brass parts first.
Who knows what has been done by a PO?
And as far as Romax's statement  "but not every part is always available, so for some parts, they must to be sourced aftermarket", that may be true but genuine parts can always be sourced from eBay and/or forums such as this one.  But shops only want to buy new parts as it's easier and less chance of buying a damaged part.
Having genuine Keihin parts is imperative to getting a good carb rebuild that will insure a good running bike.   Trust me, I've been there...
Offline newbiecb550
« Reply #19 on: March 07, 2025, 01:19:20 PM »
States away, I couldn't find any place online that was local to me and I wanted to use someone who specialized in carb rebuilds and didn't want to keep searching online. To answer your question in the other post, no I didn't pop off the carb float bowls. I just popped them off and shipped them out. When I was looking at the carbs, it seemed like a few semi stripped screws and even one of the bowls didn't seem tightened evenly with the rest. Since I have zero experience with carbs and not tons of time these days, I'd rather outsource stuff I don't feel comfortable to the experts.
Offline newbiecb550
« Reply #20 on: March 07, 2025, 01:22:16 PM »
Yeah my guess is the latter, not wanting to take chances from some one off buyer. They seem pretty reputable and looked up a few random reviews and with the warranty, I feel confident it'll run pretty solid. I'm also picking up a carb sync tool to do once it's on the bike as I found a video online on how to do it and looks super simple.
Offline newbiecb550
« Reply #21 on: March 10, 2025, 04:00:07 PM »
Alright a bit more tinkering. Got the stock air box in from eBay, looks like it’s missing some parts but I’m sure you guys will confirm. I’ve circled in photos from the assembly thread (what a huge help!!) what it didn’t include. Also came with these brackets with welded in screws. Do these look familiar to anyone? So far I’m missing the two tubular spacers, the oval shaped nut which secures the plenum to the case, the foam piece that goes on the bottom of the air box (but I do have the rectangular gasket), and missing the tool tray/air cleaner cover. Oh I’m also missing the piece that secures the air filter, small black thing circled as well. However, mine did come with this air inlet thing which I have a separate photo of. Did the seller pull this not off a CB550F?
The carbs got to the rebuild place today but wanted to test fit the air box since I’ve never messed with one. Fitting between the battery box and electronics was tight! Wasn’t sure if that’s because the PO told me he rewired the whole bike and a large wire loom hugs the frame.
Does the stock clutch cable route between the plenum stacks? That was the only way it didn’t rub. Also discovered one of the boots on the plenum is ripped, so that’ll need to be replaced.
Also took a good photo of the ripped “push” throttle cable. Pretty sure I need a new one.
I assume it was the PO who wrapped the side covers in this weird black material. Under them, the side covers had been spray painted black and you may be able to see some of the original blue. Shame. Either way I’ll run them without that ugly wrapping until I get the tank and covers painted. I’m thinking an OD green (black out the Honda emblem) with a black seat but that’s so far off I’m not really thinking much about it now.
Offline newbiecb550
« Reply #22 on: March 10, 2025, 04:02:24 PM »
More photos. And of course, the 5 out of 8 tappet covers are not coming off but instead becoming even more rounded out. So that’ll be a fun project as most looked like they were already starting to round. Mystery intake photo and random bracket bolts attached.
Offline newbiecb550
« Reply #23 on: March 10, 2025, 04:13:45 PM »
Photo of the push cable, ugly material removed from the side cover covers.
Offline newbiecb550
« Reply #24 on: March 10, 2025, 04:16:52 PM »
Last few. One of the ripped plenum boot and a starting to get rounded tappet cover. 12 point or whatever 17mm socket is trash. Tried with some 17 ratchet wrench that also went trashy. Next up 6 pt 17mm socket and 5 new tappet covers.
For those and fork seals, partzilla??
