« Reply #30 on: April 22, 2025, 02:57:56 AM »
I note that the outer bearings oil channel goes out to the sides of the head and thus the oil is forced back past the bearing whereas the channel in the inner bearing surfaces allows oil to flow into the oil cam lobes oil baths. So does the the two outer bearings get a better lubrication system than the centre? Or is this a way of diverting more pressure to the centre?
Outer bearing pic:-
What is the black coming out the oil port? Permanent, silicone??
Logged
Stu
My current rides
Prior bikes....
