You said it would not turn with kickstart when it "siezed" and that suggests something mechanically serious, you really need to take it apart again and check
It's coming apart tomorrow. I have another bike to use.
Better safe than sorry..😇
If it was your ring’s end gap butting, your piston(s) ring land(s) will more than likely be bad..
When a ring butts from heat/expansion it keeps getting hotter causing more expansion, clear to seizure..
The ring(s) that is/are butting get so hot that they micro weld the ring to the piston’s ring land on the way up.
Only to get torn off of the bottom side of the ring land on the way down…over and over until seizure….
If they experienced micro welding in the ring land(s) it’ll be an oil burner if you reuse them.…Similar to a bead blasted piston.. The rings will never experience a load during normal operation that can flatten down the torn up ring land enough to seal..Excepting maybe the top compression ring.. The oil rings will never seal after bead blasting….even standard tension ones…
Your culprit(s) piston’s may now have excessive ring to land side clearance too..Things really get hot right before it seizes.. If it’s a piston seizure it’ll be easy to spot.. 😩
