Author Topic: 1977 CB750A potential purchase questions  (Read 2914 times)
Offline Flyin900
« on: April 20, 2025, 07:12:14 PM »
I am looking at the above bike shortly and the bike has 5000 original miles and looks quite pristine. The owner notes it has a very small oil leak when hot. He doesn’t know where that is coming from at this time.
Do these models suffer from head gasket seepage or other areas that may be the culprit? It also has a couple of small holes in the twin muffler system. Given the very low mileage I suspect it was not enough heating of the system and condensation in the muffler at a baffle area. Again is this a common issue with the exhaust?
The bike has brand new tires fork seals and battery last season. Paint and chrome is pristine and the aluminum is very good in the pictures. He is looking for $3500. Firm for the bike. That is in Canadian dollars.
Any feedback would be appreciated.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline grcamna2
Re: 1977 CB750A potential purchase questions
« Reply #1 on: April 20, 2025, 08:13:14 PM »
Hi David  :), you got pictures ?
75' CB400F/'bunch o' parts'
Offline Flyin900
« Reply #2 on: April 20, 2025, 08:32:25 PM »
No pictures of the bike I don’t know how the transfer them from the site.
Offline newday777
« Reply #3 on: April 21, 2025, 03:43:04 AM »
If using your phone, take screenshots of the pictures, crop the screenshots, then hit the attachments button.
I answered in your other thread on this.
« Last Edit: April 21, 2025, 03:44:41 AM by newday777 »
Stu
My current rides
Prior bikes....
Offline Flyin900
« Reply #4 on: April 23, 2025, 03:31:27 PM »
I looked at the bike and it is in great condition and runs well. Compression was 165 X 4. The two issues which are a deal killer for me are the left muffler is quite rotten at the front area near the down pipe and almost all the way around with some JB Weld fix. The rear cones also have rot and JB Weld under the very bottom at the exit. The right muffler has a 3.5 inch JB weld repair underneath halfway down too.
Since a replacement exhaust is NLA and these ones while the chrome is good are a bit of a mess. The left one needs some type of repair to reinforce it soon.
The other issue was the bike creeps in low gear at idle. It was idling a little high so I adjusted it down and no change. It jumps when put into gear slightly. Maybe this is normal on the CB750?? The 1982 CM450 I restored didn't do this and sat motionless until you turned the throttle when in low gear.
Forgot my camera and not a phone guy never got that memo.  :)
Offline grcamna2
« Reply #5 on: April 23, 2025, 08:28:42 PM »
Too bad the exhaust was so 'patched' David.
Offline Remcod
« Reply #6 on: April 25, 2025, 01:08:13 PM »
Automatics do creep. Thats why there is a handbrake at the side. To release it you press the footbrake.
Verstuurd vanaf mijn SM-A536B met Tapatalk
« Last Edit: April 25, 2025, 01:15:45 PM by Remcod »
Offline Remcod
« Reply #7 on: April 25, 2025, 01:13:08 PM »
And let me add to that so you live another day, they do not brake on the engine either. So brake before a corner!
Other than that its one of my favourites. And yes exhausts are unobtainium, but aftermarket there are possibilities.
« Last Edit: April 25, 2025, 01:17:42 PM by Remcod »
Offline Flyin900
« Reply #8 on: April 26, 2025, 05:44:35 PM »
Thanks for the update on the creep issue. I did see the hand brake on the left side. I don't recall the 1982 CM450A creeping after I did the restoration, yet that was a 5 years ago and the memory isn't great.
The exhaust was the deal breaker along with the creep, plus I wanted a little more oomph from the bike. I just restored a 1984 CB450SC Nighthawk and it seems about the same power level as the 750A bike. I would like a little more giddy up for the larger bike size that it brings.
