Author Topic: Best way to repair odometer zeroer CB400F?  (Read 673 times)
Offline marsbound
« on: May 09, 2025, 11:10:16 AM »
The odometer zeroing knob on my CB400F is a bit bent, and the rubber grommet for it has come off/out of the instrument cluster. Photo attached. I bought some more grommets, but I can't find any instructions on disassembling/reassembling.
Re: Best way to repair odometer zeroer CB400F?
« Reply #1 on: May 09, 2025, 12:48:16 PM »
 Taking the gauge apart is not a simple task, I'd attempt to straighten it maybe with two needle nose pliers and tuck the boot in with a non-sharp but pointy tool.
Offline Mark1976
« Reply #2 on: May 09, 2025, 01:27:31 PM »
   To be honest, it's a common problem, one of mine has the same issue. I've just learned to live with it, and don't ride in the rain.... If someone's got a solution, (short of disassembly) I'm all ears...
Start with the end in mind...
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #3 on: May 10, 2025, 07:34:28 AM »
To fix it correctly you will need to separate the case. The 400F does not have a screw or set screw holding the knob on. The small rusted shaft you see is part of the knob. It screws into the aluminum body  of the odometer. You need to use a hot iron to heat it up as it is secured with lock tight.holding each side with needle nose pliers. My soldering iron would not get it hot enough so I heated a nail red hot with a torch and applied heat that way
 This is not an easy fix.
1976 Z50A PARAKEET YELLOW
1970 CT70  CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVIERA BLUE
1974 CB350F GLORY BLUE BLACK METALLIC
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
Offline Rayzerman
« Reply #4 on: May 10, 2025, 03:23:43 PM »
If going the dissassembly route, here's a long video......  also another website to look at.
https://www.dimecitycycles.com/blog/honda-cb-gauge-disassembly-and-face-replacement.html
