Author Topic: dellorto carbies  (Read 1720 times)
Offline topgun
dellorto carbies
« on: May 12, 2025, 11:19:20 AM »
Hi Guys I have bought a pair of 40mm Dellortos for my 750 and the linkage brackets for the throttle cables  are missing can anyone help me out with a source to acquire some or possibly the measurements of the brackets so i may make some up they look fairly simple from some photos i have seen i,m located in  Brisbane Australia    Tia
« Last Edit: May 12, 2025, 09:10:15 PM by topgun »
Offline topgun
Re: dellorto carbies
« Reply #1 on: May 12, 2025, 09:11:08 PM »
« Reply #2 on: May 12, 2025, 09:18:27 PM »
I'm not sure which brackets you are referring to? Which manifold are you using? The RC manifolds had a receptacle for the end of a cable outer on each end, for use with a two-into-one cable. The MPD manifolds had a central receptacle for a single cable.
Offline johno
« Reply #3 on: May 13, 2025, 05:42:11 AM »
Could be anything or any brand manifold Top gun , need a pic of manifolds.
The most common Delorto distributers in OZ were / are ? Lynx industries. The produced their own manifold and rubbers and air cleaners.
I installed a few sets and they were OK. I liked watching the rubber manifolds pulse at idle they were so thin.
I don't know if Lynx are still in the game , they were Sydney based. Google them top gun and see what happens,
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
Offline topgun
« Reply #4 on: May 14, 2025, 11:40:39 AM »
Hi Guys the manifolds are Lynx and the previous owner made a custom set-up for the throttle cables but I can't for the life of me work it out so I thought it would be easier to make or source the original version which look quite simple
Offline topgun
« Reply #5 on: May 14, 2025, 11:42:37 AM »
More photos
Offline topgun
« Reply #6 on: May 14, 2025, 11:44:02 AM »
More photos
Offline johno
« Reply #7 on: May 17, 2025, 04:47:32 AM »
you have interesting linkages topgun. ;D
Webber carbies in Melbourne sell the original cable for left & right hand carbs.
Just curious, what ventures are you running ?
cheers Johno
« Last Edit: May 17, 2025, 02:02:14 PM by Don R »
