Author Topic: '75 CB550K1: The Driveway Shop  (Read 1361 times)
Offline ThelassianLupus
« on: May 13, 2025, 05:55:31 PM »
Thought I'd share what I did today and start a thread for the ongoing maintenance of my CB550.
I'm not an experienced mechanic, but I was very eager to start learning when I got this bike. I bought it from a friend two years ago after taking a rider course and I've been riding and working on it ever since.
Re: '75 CB550K1: The Driveway Shop
« Reply #1 on: May 13, 2025, 06:02:17 PM »
One job I did last summer was a rebuild of the brake caliper. I think I did it poorly because the front wheel wouldn't turn freely and squeaked loudly at low speeds. So last week I decided to remedy that problem, while inspecting things I found that the brake hoses were cracked and needed to go.
« Reply #2 on: May 13, 2025, 06:11:24 PM »
I took apart the master cylinder and caliper. All the rusty parts got an evaporust bath and cleanup while I waited for the new brake lines. Unfortunately this bike has a lot of rust I even found some on the tank and it looks to be under the paint in one spot. Underneath all the grease, grime, and rust I know there's a beautiful bike here!
Online denward17
« Reply #3 on: May 13, 2025, 06:51:39 PM »
Looks to have good bones, following on progress.
What's your plan for the bike?
I think I would address that tank so it won't rust any further and start leaking.
« Reply #4 on: May 13, 2025, 10:24:30 PM »
Removable rust, otherwise looks like a good starting point from here?
When you go to reassemble that brake caliper, install new rubber seal(s) on the piston in that caliper. They may be damaged from crud and are surely hard from age. The way the caliper retracts the puck is: when the brake is applied the puck slightly edges outward to make disc contact, and when released the rubber seals around that piston will pull the piston back when you release the brake lever. This is about 0.002" travel, typically: when the rubber is real old it no longer grips onto the puck so it slips out, and then it won't retract it, either. Then the pad drags, and squeaks.
And then, new rubber seals make it retract better again. It ain't much movement, but it's important!
« Reply #5 on: May 14, 2025, 07:57:18 AM »
Also check that all the moving parts on the support arm move freely. Fresh grease on the pin helps.
« Reply #6 on: May 14, 2025, 11:05:28 AM »
I appreciate this advice, but I regret to say I already reassembled the caliper. I imagine a fresh seal would have made it easier to seat the piston back in the caliper housing as well. The fit was really tight.
I'm noticing a slight slant on the surface of this brake pad and some gouge marks. Does this warrant replacing? If so I'll grab a new ring seal while I'm buying pads :D
« Reply #7 on: May 14, 2025, 11:30:56 AM »
Definitely looking to fix the tank soon. Any methods you'd recommend? I was thinking angle grinder with a wire wheel, though that approach may lack refinement.
I plan to use my available means to the best of my ability to keep this bike in great working condition. I don't want to sell it, or even really restore it to be "like new". I like it as an ongoing passion project and it's been a really great opportunity to learn and rely on this machine.
 I daydream sometimes about customizing it for use on some of the rougher roads in northern Maine so I can go on some more rugged adventures. But so far the most "custom" work I've done is the ammo can panniers. They have working turn signals though!
« Reply #8 on: May 15, 2025, 10:36:39 AM »
Those are some cool saddlebags! :D
Online denward17
« Reply #9 on: May 15, 2025, 11:24:39 AM »
Just normal, sanding down/priming/painting, assuming no pin holes.
« Reply #10 on: May 15, 2025, 07:24:02 PM »
It looks like the tires on it are good for "dirt road encounters", as we used to call them. It's good to consider alternate tire patterns, away from high-speed hiway types, for those non-paved adventure rides. I might raise one point to consider when thinking of new tires: don't go larger than 110/90x18 rear in size, or maybe 120/80x18 for a little wider footprint, or else you'll discover the sidestand becomes too short! The 80-profile tire will help prevent that little bug from biting. The 80-profile tire today is closer to the old 3.75x18 rear tire it sported from Honda.
« Reply #11 on: May 16, 2025, 10:35:56 AM »
If you still have the caliper off the bike, I would install new pads and a seal.  If no, ride on!
« Reply #12 on: November 23, 2025, 04:41:40 PM »
“I appreciate this advice, but I regret to say I already reassembled the caliper. I imagine a fresh seal would have made it easier to seat the piston back in the caliper housing as well. The fit was really tight”
What makes the fit “really tight” is not usually an old seal. The grove the seal sits in must be absolutely spotlessly clean. The crusty crap that builds up in there is hard to spot and even harder to remove. I use a dental pick and a tiny wire wheel on my Dremel. If there is any scale left behind, the seal doesn’t seat properly and that causes the piston to stick, leading to brake drag.
« Reply #13 on: November 26, 2025, 10:51:17 AM »
Okay awesome, noted. At some point I'd like to tackle the front end and I'll be sure to include cleaning the caliper housing seal groove.
