Heya all,
Been a while since I’ve had a problem that has stumped me and my engineer son but mows the time to fess up …
I found a very nice barn find 350-4 with faded paint and stock perfect exhausts BUt it was pudding a small amount of smoke out of the cam box vent hose.
I checked compression which was low and a couple of the valves were leaking.
I had my local bike rebore experts lightly hone the cylinders; I fitted a couple of new valves, decoked the head, installed new viton stem seals, polished the valve heads and lapped the valves.
Also added new Dyna coils and genuine points and condensers.
Ultra sonically cleaned the carbs then made sure all passageways and orifices were clear; installed new genuine jets and set the fuel level at 21 mm, which proved to be too high and so, based on Hondamans commentary we set the foot height at 21mm
After the new pistons and rings were fitted and with the bike cool not cold compression is130 on every cylinder and 138 to 140 when hot.
Needles were initially set with the clip on the centre as per standard specs.
Now the fun starts…..
Bike starts readily on the choke but slowly stumbles and dies while spewing black smoke in copious amounts. Starts again easily and after revving it to clear it a little same thing happens - slowly stumbles and dies while spewing.
I lowered the needles one notch, made sure the drain tubes in the carbs were clear and weren’t split and the hoses were free and clear, rechecked the valve clearances, checked the cam timing, ignition timing, fitted new plug wires and fitted new resistor caps and resistor plugs just to be certain I hadn’t missed an obvious problem. Oh and checked the choke operation to ensure the choke wasn’t the problem.
So back to the startup - I removed the plenum so I could confirm the choke wasn’t slowly operating and once again the bike starts easily on the choke but as it warms up it starts to blow smoke and slowly stumbles and dies while spewing smoke.
So after all the work and rechecking, the operation is identical and the problem is identical…..
What are we missing? It’s gotta be something obvious and simple but I can’t see it for the black smoke …..
