Why would Honda adhere to a smog law with the 77/78 550K but not with the 77/78 550F (-early F models had exactly the same carbs as the later (77/78) F models)?
John
That's a good point John.
It was because of "Type Acceptance" rules that were set up at the time. It went like this: if you could make your bike#1 pass emissions law for the 1973 model year, you were given [n] number of years that you could build them just like the first one. If you changed anything involving carbs, pipes, or engine configuration of displacement (or cam), then you had to follow the NEW rules that were set up for the model year in which this new version came out.
So, the 1973-introduced CB500F/550F bikes had the same carbs and pipes all the way thru their run, while the CB500/550K bike, which was changed considerably in 1976, had to follow another set of rules. Then again, the last 2 years, with the improved rocker shaft cam-cover engines, had different pipes again, so they had to follow yet another set of laws.
That's how it all happened, and why there are 5 different carbs in as many years on this bike.
