Interested, I have a K5 daily driver with an annoying stumble somewhere between 2500-3500 RPM light load cruise when slightly opening throttle. Hasn't always done this, off and on between carb rebuilds and miles over the year but is back to doing it. Granted weather has been around 100* for a bit that it seems more prominent, maybe related. Changed the oil today, it's overdue. I'll adjust valves, tension cam chain, and sync carbs tomorrow... also likely overdue.
Mine has a Dyna S and iridium plugs, for reference. Generally seems to make for easier cold start and smoother cold running than points and copper plugs. I should probably check timing, haven't done that probably since installing the Dyna.
