Author Topic: Advice needed on engine case points cover repair  (Read 495 times)
Offline Bristledisk
« on: July 02, 2025, 07:22:17 AM »
Where my points cover screw in to the engine casing on my 350f, the screw in part on the engine casing is broken. See image below circled in red. The cover will screw in and hold, but any suggestions on how to best fix the damage?
1977 CB400F, 1976 CB750F1, 1974 CB550K, 1975 CB550K, 1976 CB550K2, 1973 CB350F
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Advice needed on engine case points cover repair
« Reply #1 on: July 02, 2025, 07:37:55 AM »
Welcome!
That's an ouch.
It might be dicey but something like JB Weld might be able to be built up there and drilled and tapped. You'd have to make a form to shape it. There may be other similar easily shaped products that others on the forum know about that would be easier to shape. Have to really clean the area so it will stick.
Just guessing.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #2 on: July 02, 2025, 08:39:03 AM »
Almost like my CB750 case.
It had enough threads for an M6 bolt to shoot in place, tightened until bottom.
I had sprayed it with Teflon spray first and let it dry before tighten it.
After that JB Weld, the epoxy version that need several hours to harden.
Unscrew bolt when hardened.
This was an empty set of cases. So important to test mount crankshaft and all covers to verify no other issues.
The lower case was glass beaded to find more. Lower fastening ear on right side was welded.
Here with a Dyna-S
« Last Edit: July 02, 2025, 08:44:43 AM by PeWe »
« Reply #3 on: July 02, 2025, 08:53:29 AM »
Devcon F(i think) but be seated before checking price
Offline Tracksnblades1
« Reply #4 on: July 02, 2025, 09:20:16 AM »
Here with a Dyna-S
What caused these..?
Light drops…?
Age Quod Agis
Offline Bristledisk
« Reply #5 on: July 02, 2025, 10:33:08 AM »
Thanks for the replies. I’ll try the JB Weld. My CB350F was already damaged when I got the bike, but I’m thinking it was over tightened at some point
« Reply #6 on: July 02, 2025, 10:48:42 AM »
Probably a dropped bike for my cases.
Lower case was welded by a PO. So that can be something to look for.
First thing after cleaning with a power washer inside all oil channels was to assemble it with a crankshaft and bearings.
It rotated nice all the way to 25Nm in 5Nm steps each time.
All clearances were close for all journals/bearings (green), matched the case numbers (B) vs crank (A).
No other seen damages. (Same clearances I got with my K6 engine).
I had warranty from the guy I bought it from ;D
Later adaptation for bigger bore and got fresh paint.
« Reply #7 on: July 02, 2025, 02:51:46 PM »
 There used to be an epoxy that you could put over a fastener that had a release agent so the fastener could be removed from it after it had set up. I don't remember the name, it might be a JB Weld or Permatex product.
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #8 on: July 02, 2025, 05:40:19 PM »
Coat a new screw with wax,that will aid in removal. Install it on the remaining threads, build it up with JB weld ensuring you get in into the screw threads. It should last another 50 years as long as you don't tighten it with a impact wrench
1976 Z50A PARAKEET YELLOW
1970 CT70  CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVIERA BLUE
1974 CB350F GLORY BLUE BLACK METALLIC
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
