Author Topic: Cracked overflow tube on early float bowl!  (Read 1006 times)
Offline slyguy
« on: July 13, 2025, 05:04:15 PM »
I saw it got way bent & I gave my carbs to an old timer friend to inspect & reassemble but he said the tube was cracked & will try to fix. My questions are; anybody got a good spare available(since I can’t find one..reasonable anyway) or would the fix be using an epoxy like jbweld that’s fuel resistant?? Tia!
Offline newday777
Re: Cracked overflow tube on early float bowl!
« Reply #1 on: July 13, 2025, 06:15:33 PM »
What bike???
Stu
My current rides
Prior bikes....
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: July 13, 2025, 08:38:57 PM »
Clean it, flux and solder with the correct solder for copper/brass.
Offline newday777
« Reply #3 on: July 14, 2025, 02:50:20 AM »
That is what I have done.
Stu
My current rides
Prior bikes....
Offline slyguy
« Reply #4 on: July 14, 2025, 08:15:00 AM »
What bike???
70’ cb750ko 4-1cable carbs
Offline BenelliSEI
  • 1969 cb750
« Reply #5 on: July 14, 2025, 12:24:34 PM »
Here’s one I soldered up. It had a crack right up the side of the tube. No idea how this happens! Condensation and then frost? No one seems to have a good explanation. Vibration?
Offline slyguy
« Reply #6 on: July 14, 2025, 06:46:07 PM »
Thanks guys👍 we’ll give it a shot!
Offline newday777
« Reply #7 on: July 14, 2025, 07:25:39 PM »
Water in the gas, yes condensation, then freezing temps to expand the brass like copper pipes do when frozen.
Stu
My current rides
Prior bikes....
Offline jpschroeder
« Reply #8 on: July 15, 2025, 06:09:23 AM »
I soldered one successfully too, on a smaller cb350f bowl. Use lots of flux on the outside and try to be fast so you don’t weaken the aluminum bowl to copper connection. Solder upside down so the solder drips away from the tube and won’t clog it, rely on the solder to wick it into the crack.
« Reply #9 on: July 15, 2025, 07:36:15 AM »
I have wondered if you could drill and tap the floatbowl the screw in some brass tube, keep meaning to try it but have never got a floatbowl, taps, dies, tube and time all together at once!!!
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #10 on: July 15, 2025, 07:44:50 AM »
Solder looks like a good fix, not to complicated, cleanliness is important.
Glad we don't have freeze/thaw here!
1973 CB 750 K3
10/72 build Z1 Kawasaki
