Author Topic: CB550 Performance Mods, A La HondaMan...  (Read 48214 times)
Offline MTRD3
Re: CB550 Performance Mods, A La HondaMan...
« Reply #75 on: February 24, 2015, 12:58:28 PM »
Some increased volume over the intake valves (also called 'pocket porting'), reduced sides of the guide bosses, nice smoothing of the casting marks, and a good job of matching the intake castings to the head ports is what it takes. ;)
If one doesn't understand the context or references made in ^ that post, would you say their mechanical, or perhaps better said, engine based knowledge is far too rudimentary to be able to properly (in order to safely carry out the work) learn or attempt to do any of the DIY engine work mentioned in this thread?
I fear that my enthusiasm and ambition encourages endeavours that are far too lofty for my abilities/knowledge level.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #76 on: February 24, 2015, 06:12:13 PM »
You don't need to be an engine expert to attempt some porting. Just don't go whole hog.
Bigger isn't better when it comes to poring. I'd go to the library and do a bit of reading on the subject. The are also some really good porting chapters in small block Chevy performance books that discuss pocket porting with good photos to help visualize the concept.
« Reply #77 on: February 25, 2015, 11:26:08 PM »
The main things to look into improving in the 500/550 head are pretty straightforward. Since these engines let you pull the head in the frame, it is easy to do-a-little, ride-a-little, repeat until it suits your taste. ;)
When you look at the ceiling above the intake valve, you will see it forms a tight wedge into the valve seat. This particular area is responsible for killing the once-excellent air inertia from the long intake runners back to the carbs. If you instead pocket it a little right here, the air mass will compress itself somewhat during the snapped-shut valve time, and will be more eager to enter the cylinder at the next intake stroke, still being at higher pressure when the valve starts to open. The total volume should not exceed the volume of the port for the same depth upstream, though, or the flow will stall and a flat spot will develop in that RPM range. This is known as "over-porting".
To then take full advantage of this compressed intake flow, the edges of the valve seats insdie the combustion chamber must also be cleared (and sometimes the nearby cylinder wall moved back a nick or two) or else it takes longer to start moving. A small amount of change makes a real noticeable performance change, simply because these engines were made in molds where this was too difficult to [manually] control in the 1970s for their cost targets. By the time of the 750F1 the molds and ports had become works of art, but that never quite made it to the Mid four bikes (it did to the CB650 and 400F, though!).
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #78 on: February 26, 2015, 12:33:43 AM »
Awesome contribution (as usual) HondaMan!
Thanks
Offline joegeis
  • '78 Honda CB550k
    • Photo Album
« Reply #79 on: July 05, 2025, 07:58:08 AM »
Hello from 10 years in the future! I know its a long shot, but is there any chance to photos from the OP are still out there and could be rehosted somewhere new?
Offline crazypj
  • I'm brill, me
« Reply #80 on: July 24, 2025, 07:35:45 AM »
Unless OP downloaded al pics from Photobucket and is prepared to go through and find pics they are gone for good.
I downloaded my pics as Photobucket was deleting them from server but found I had quite a lot to go through even after deleting a few albums when Photobucket first decided to hold people hostage.
As thread started about 18 years ago, it's probable pictures will not be re-uploaded
« Reply #81 on: July 24, 2025, 09:43:50 AM »
There's some pics of it in Section VI of my newest book. ;)
